Hello.
I use Windows 7 x64 and When I want open a document in my local network, The InDesign CC or CS6 can't show some photos that exist in the document. Why? I removed and reinstall my InDesign and updated it too but problem exist. Any idea to solve it?
Thank you.
Can you be more specific? Your post really doesn’t make much sense.
Perhaps some screenshots would help.
In our Fileserver, We have some folders like, InDesign documents, PDF, Photos and... We create an InDesign document and use the photos that exist in "Photos" folder and As you know the InDesign use the photo Link inside the document. When we open this document on another PC then InDesign can't show some photos that exist in the document!!! All PCs are in a same local network with same InDesign version. What is our problem?
Thank you.
Can you see those folders using the operating system?
Yes.
The user has full permission on that Folder. It is so odd for us and is a serious problem.
Do you get an alert when opening the file about missing links? Modified links?
Can you place from those folders? Drag/drop from those folders?
Not really, InDesign never show any error about missing or modified links.
Yes, I can open the folder and copy,paste and delete files.
Just a simple question. What format are they pictures in? If they are raw pictures i'm not sure that indesign can read those.
JPG
We need to back up. What does "can't show" mean?
The photo in document is empty.
Screenshot please? Is it a gray box?
If so, change the display performance under the view menu. If it's set to fast, that would give you the gray boxes.
Please don't consider Yellow sign, I just Open any photos that not have any Yellow sign. As you see I selected four photos and when wants to open it via Adobe Photoshop, The InDesign can't open them correctly in document and Photoshop just open 1 or 2 of my photos:
What is the root of this problem?
