I can't get the contact form working on third party server. Works OK uploaded to business catalyst.
The PHP check ( http://my-site.com/scripts/form_check.php
gives all green checkmarks.
I've contacted my hosting company (cloud next) and they have asked if:-
quote
Hi Peter,
Can you confirm that in the configuration of the script you have configured an SMTP server as well as a valid to/from email address as configured on this account?
Kind regards
Cloud Next
Unquote
As I'm not a PHP developer i'm not sure.
Please advise, If I can't get forms to work I'll be terminating my Adobe Muse subscription.
regards
Peter
Muse form works through PHP MAIL, not SMTP. Some hosting providers do not support php mail. Apparently your hosting provider is one of these. To customize your form via SMTP, you must be php coder. And even if you are able to do this through code, it will be still some disadvantages - you have every time separately from the muse place handler php file on the server. A much easier way - just change the hosting provider. It's poor tone if the hosting provider does not support php mail.
I've contacted the hosting provider again, their repose was:-
quote
Hi Peter,
PHP Mail is supported, but for us to be able to see what is going on (checking the mail logs etc to see what is happening with the email on your form) it does need to be routed through an SMTP server.
Kind regards
Cloud Next
unquote
I responded
Ok, so I suppose Adobe muse forms are not going to work on Cloud Next servers without addition scripting?
they responded
quote
Hi Peter,
We do always recommend configuring an SMTP server with a valid to/from mailbox as configured on the hosting when using forms on our platform.
Kind regards
Cloud Next
unquote
Not sure where that leaves me, between a rock and a hard place I suppose. I have 5 website with Cloud Next (designed in Freeway Pro with working contact forms). Muse for some reason does not seem the work though.
Does anyone know what the script form_check.php actually does? My hosting company is querying the code below.
quote
Hi Peter,
Looking through those scripts and I don't think it's setup right, looking at the script form_check.php there is this line of code:
$sent = mail("recipient@example.com", "Hi", "test message", "From: sender@example.com");
obviously those details appear to be incorrect.
Kind regards
unquote
Change your hoting provider. In normal hosting it works by default.
