The filmstrip is backwards. I don't know how I did this. How can I fix it?
It's on the toolbar in the library grid view. If the toolbar isn't visible just above the film strip press the T key. If the toolbar is displayed but there is no sort order, click on the little triangle at the right end of the tool bar and make sure the toolbar option has a checkmark.
If you are talking about the sort order, you can set that order in the toolbar in the library module.
Files are always it the time sequence. I'm working on a wedding and suddenly the sequence is reversed with the final shot first.
I don't know how to fix it. I'm not seeing anything re. "sort"
Mike
In Library Module, go to Grid View. You should then see the sort order selection in the lower left. Click on the (AZ) icon to reverse the sort order.
This is my view, no az.
Got it. Sorting is on the other side in the pulldown next to the thumbnail slider.
Thank you Thank you Thank you............
