I'm trying to shoot RAW with my new camera. LR won't accept the files and the DNR converter doesn't include my new camera yet. Anything I can do other that shoot jpegs?
David
[Moved from non-technical Forum Lounge to specific Program forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
you can't shoot TIF files, you have to convert the RAWs to TIF
If you shoot RAW (and then convert to TIF) you get the benefits of RAW, which is primarily higher image quality after editing than you would get from a JPG of the same image. This is because RAW files capture the image at a higher bit depth per pixel (usually 12 or 14 bits) and thus you have more information to work with than a JPG, which is always 8 bits per pixel.
Correct - support has not yet been added: Cameras supported by Camera Raw
Adobe will probably add it in the next release/update.
When? Only Adobe knows and they won't tell
David
What I have been doing is to convert to tiff files with the Sony raw converter (Sony website) by first putting them into a folder on the desktop and then importing the tiffs into LR. The tiff files are 50mb but you can then dump them after the psds or jpegs are produced.
BTW Sony recommends Capture 1 express version for Sony but it also does not yet support the RX100V.
There is another raw converter by Iridium but the trial version produces watermarked results and the license is $99.
Jerry
... The tiff files are 50mb but you can then dump them after the psds or jpegs are produced.
This doesn't really makes sense.
I shoot in raw and quickly found that Adobe Lightroom and Phase One have no support for the RX100 V. They both support older models, but not the V. Adobe is aware of the issue but said they have no timetable to support. So if you buy the most recent version of the RX100 and shoot in raw, you are not able to use 😞
You can use the software that came with the camera to convert the RAW photos to TIF, and then import the TIF into Lightroom.
That's exactly what has already been said
Actually, this is not an issue. Due to the fact that camera manufacturers decide to sightly change the RAW file format for every new camera it is not possible for Adobe to create an import that works for, let's say all Sony's.
In fact, Adobe is rather fast in releasing an update that includes support for the new models.
Thanks for the info. For this very amateur, why shoot tiff, rather than just use jpeg until the RAW converter comes out?
Thanks to all. I downloaded the Sony Image Converter, converted some sample RAW pictures from my new camera to TIFF, then edited the TIFF files in LR. I then exported the 50MB TIFF files to my computer as 170KB jpegs. Never would have gotten here without the help from this site. Thanks much.
David
You are only looking for a short-term solution. It might be days, it might be weeks. But eventually Lightroom and the DNG converter WILL support the camera. In the meantime, do what you need to do to satisfy your photography needs. It's your choice. There isn't anything any of us can do to resolve the issue. The update will eventually be released that supports your camera.
