Hello,
I purchased by Adobe Photoshop and First Elements 15 download.
I ask myself a question before installing them.
I'm making a slideshow under Premiere Elements 10 (with titles, comments, music, effects ...) that I can not finish now.
Do I have to uninstall this version 10 before installing version 15 and in this case will this file be converted correctly under version 15 to be able to finish it later ?
I am on PC and Windows 7.
Thank you very much if you can answer me.
You don't have to uninstall version 10, as each version is an independent program. You can have many different versions installed.
You may or may not be able to open a version 10 project in version 15, depending upon effects used. Make a copy of your project file and you can try it. It is, however, recommended to finish a project in the version that it was created.
Moving to Premiere Elements​
Hello,
I just upgraded from version 10 to 15, does anyone know if there is additional transitions available for version 15? I'm looking to get more "Hollywood Stlye' transition effects like the ones that come with Pinnical...
Thank you!
See here:
https://www.prodad.com/Home-29756,l-us.html
Also, a lot of these are available for Premiere Elements:
Thank you Bod. The information is useful and relevant. I appreciate your help and time!!!
You're welcome.
Peru Bob wrote:
See here:
Those links go to options for Premier Pro. Do they apply to Premier Elements?
Thanks.
Bill
Some of those applications have Premiere Elements versions.
I have used ProDad products on Premiere Elements.
Thanks. I bought a ProDad product that did not install in PrE, but will run stand alone. It will be fun to check some of the other apps.
Bill
