is it a bug in the new version? happened in different projects- i send my HD comp from after effects to queue nicely, and suddenly encoder is saying that its a 940x 540 comp. if I try to resize it ruins the quality, as if my material is too small... it 4K!!! I am very pissed off and can not find an answer...
please help
thank you
[Moved from non-technical Forum Lounge to specific Program forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
Yes! And there is an easy workaround.
Just set your comp resolution to full and save it that way before you send it.
It's a silly bug and Adobe says there is a bug fix update coming soon (but they haven't said if this bug is one of those that'll be fixed). But, until then, we have a workaround.
Thank you very much for answering!
there are so many bugs i am seriously considering downgrading back to 2015.3- i am loosing so much time- and, therefor money, and clients, to figure out all these workarounds. !
actually 2015.3 has some nasty bugs too. other than this bug which has very easy workarounds, what other bugs have you discovered in CC 2017?
in AME, no, but in primiere pro, i experienced different bugs regarding sound...
try this:
If you change the audio device being used in Preferences > Audio Hardware, does the problem go away? We think it may be more likely to happen if you have a multi-channel capable device. If you switch to a stereo-only device (ex., internal speakers), this may be less likely to happen.
it was taken from this thread: CreativeCOW
thank you, but nope, didn't work- I do not have another device available to switch to... I have posted a Q. in the premiere pro forum, maybe ill get some answers there...
You could try the latest update that came out last night: After Effects CC (November 2017) Bug-Fix Update Is Now Available
This update is 14.0.1 and fixes several disturbing issues - especially for Mac users. It does not fix all the bugs that are new with the CC 2017 release (Known issues in After Effects CC 2017), but it does fix some issues that have been plaguing After Effects since the first parts of the new architecture showed up in the CC 2015 release.
If you can't see the update yet, you may need to wait a while until you see it as it can take up to 24 hours to populate an update across all the data centers. You may need to log out, relaunch the Creative Cloud app, and log in again.
in addition to what Szalam suggested, you can also use the new Queue in AME feature which is superior method that also keeps your render settings. it will cause you no problems related to this bug.
cheers! that helped...
