Acrobat 11.0.18
MacPro OS 10.11.6
processor 3.5 GHz 6-core Intel Xeon E5
Memory 16 GB 1866 DDR3
Graphics AMD FirePro D300 2048MB
Apple LED Cinema Display 1920 x 1200
Apple Cinema Display 1680 x 1050
Acrobat is very slow to open pdf pages which have a picture or figures. Wait for 10 sec. or even more to open the page. Same file will be opened quickly on my MacBook pro with Acrobat 10.
Tried to change the page display preferences: low the custom resolution to 72 pixels/inch, and change smooth text to: None. No help.
Thanks for any reply.
Same computer, same file opened with Acrobat pro 9.5.5, no problem.
Hello,
This may happen with the file using more images or with drawings.
If you want to Acrobat/Reader to render those fast. You may go to preference > Page Display, uncheck "Smooth line art" , "Smooth images.
There has been a number of changes way the files is being rendered from previous versions.
Tariq Dar
Hello
I have been having problems since updating to Acrobat Pro DC 2015 020 20042. Opening pdf's now takes an eternity and editing also. Shows the spinning wheel often.
Unchecked "Smooth line art", no difference apart from making the page look naff.
Really need help on this one please
MacPro
8 core
64GB ram
1TB flash storage
MacOS Sierra v10 12 1
Hello again
I think I have found what is causing Acrobat to slow up. My laptop has Acrobat on it and it works as fast as it ever has. As soon as I used the sign function with signature, the program slowed right down and is now as bad as it is on my MacPro.
I did go through to support who tried to fix the problem prior to this and it was explained as a known problem after about an hours work trying to fix it.
Any comments
Hello,
Thank you for the updates.
We have released a latest quarterly update and you may try to install the update on your machine. Restart the machine and try again.
Please let us know if that helps you out.
-Tariq Dar.
