How do I search for photos in lightroom that are on my computer by file name? When i go to library > Find. I enter in my favourites list copied from Pixieset and paste it in the search field and it comes up with no photos match filter.
Do you want to search for photos that you want to then import into LR? Or do you want to search in LR's catalog for photos you've already imported?
The title indicates you want to search for photos you have NOT imported yet. The Lightroom Library/Find command will only search for photos that are ALREADY imported into Lightroom.
I have Pixie set and My client made a favorites list. Pixieset says i can import the flavorites list into light room by pasting the file names in the search bar in the find section but they are not showing up. Also i just installed the Pixieset plug in and non of my online collections are showing up in light room
Pasting the favorites list CORRECTLY in the search field might work but ONLY if the photos are already imported into Lightroom. Are these photos already in Lightroom???
Hey Bob yes you were right about that thanks! i imported the whole album and then in the search field I put i the favorites list and they all popesd up so thats great. Now how do i take just those selected photos over to develop. I highlighted all 50 favourite photos but when i click important it starts importing all my albums, not just the 50 favourite photos
We probably need a better description (step by step) of what you did, as "import" would be a wrong step here.
After you highlight the 50 images, click "develop" and you can then edit those 50 images.
You might get an answer more quickly by contacting Pixeset for help about their plugin: Customer Feedback for Pixieset . While I've seen a few Pixeset users post here over the past year, I don't think there are many who frequent this forum.
From what you said here, I'm guessing that the photos you have online in Pixieset aren't in your LR catalog, which is why Library > Find doesn't find them. So the first step is to make sure you've got the plugin working correctly.
Hi Robyn!
I love to use Pixieset, and too had troubles at first. So this is what you should do:
To update the Pixieset's Publishing service from Lightroom, right click on the Publish service and click Edit Settings. Make sure that the login information is correct and you're logged in. Click Sync Now if you want to sync the structure (collections and sets). Notice that this will NOT import any pictures, just resync the structure so Lightroom and Pixieset can talk to each other correctly.
If you want to double check your process to show client's favorites in Lightroom, here are the step by step instructions:
For the future, and now that you've installed Pixieset into Lightroom, you upload your pictures directly from Lightroom to Pixieset, making it easier to find the favorite pictures!
