How can "clickable" endnotes in Word-document (Office 2010 Home) also be clickable endnotes in PDF-document after one has saved a Word-doc. as a PDF-doc.?
Clickable means here that when the cursor is placed on the left side of an endnote number, one can by a double-click jump to the end of the doc. where the endnote text is. In the same way, one can jump from the end of the doc. and back to the endnote number in the main text. In Word 2010, these endnotes are clickable automatically.
I would be very grateful for help on this task. I do not wish to make - manually - "hyperlinks" for all my over 600 endnotes in my doc.
Thank you in advance.
Best regards,
Soeren, Denmark
It doesn't look like Word is able to do that out of the box. I was able to dig up this link for a macro that should convert all of the footnotes to links and remove them as well to reverse the process. Maybe this will help:
Hyperlink Footnotes in Word 2013 so they will export as hyperlinked in - Microsoft Community
Thank you for the help.
I am not an IT-expert. Therefore, I will ask such one to check the link you sent.
Thanks again.
BR, Soeren
