Locked
Is it possible to install in Premiere Pro CC 2017 the panel plug-in using ExpManCmd.exe ?
Nov 13, 2016 Nov 13, 2016
It runs the ExpManCmd.exe to install the panel plug-in can not be installed returns the status value of -403.
There was no problem in Premiere Pro CC 2015.4, but is a situation that can not resolve the problem Premiere Pro CC 2017.
*OS is Windows7.
I am developing the panel plug-in of Premiere Pro of my for customers.
Customer's environment can not use a internet.
For this reason it is necessary to install by ExpManCmd.exe.
Thank you.
SDK
1.8K
Community Beginner , Nov 17, 2016 Nov 17, 2016
I have solved the problem.
On my PC there were two problems with running ExManCmd.
1. 'Failed to install, status = -403!'
   I found a workaround.
   Uninstalling 'Extention Manager CC' solved it.
2. 'Failed to install, status = -411!'
   This error code could be solved with your advice.
Thank you very much.
Adobe Employee ,
Nov 14, 2016 Nov 14, 2016
What versions of PPro does your panel's manifest say it supports?
This is the version description in manifest.html of my plugin.
<ExecutionEnvironment>
  <HostList>
   <Host Version="[7.0,11.0]" Name="PPRO"/>
  </HostList>
  <LocaleList>
   <Locale Code="All"/>
  </LocaleList>
  <RequiredRuntimeList>
   <RequiredRuntime Version="6.0" Name="CSXS"/>
  </RequiredRuntimeList>
</ExecutionEnvironment>
Adobe Employee ,
Nov 15, 2016 Nov 15, 2016
That should work.
Perhaps you're running an older version of ExManCmd? Here's the latest.
Can you post the .zxp somewhere, for me? [Our mail gateway will block it.]
ExManCmd seems to be the latest version.
I will inform the date of the ExManCmd I am using.
2016/10/21  21:30         1,045,680 adobe_caps.dll
2016/10/21  21:30           238,792 ExManBridgeTalkCmd.exe
2016/10/21  21:30         1,824,456 ExManCmd.exe
2016/10/21  21:30         5,334,728 ExManCoreLib64.dll
2016/10/21  21:30            20,974 ExManCoreLib64.lib
2016/10/21  21:30         1,050,312 ExManEscalatedPrivilegeServer.exe
2016/10/21  21:30         3,009,736 ExManZxpSign.dll
2016/10/21  21:30         1,682,088 IMSLib.dll
2016/10/21  21:30         1,657,032 libeay32.dll
2016/10/21  21:53               203 README
2016/10/21  21:30           351,944 ssleay32.dll
2016/10/21  21:30           153,800 VulcanMessage4.dll
2016/10/21  21:32           188,825 XManConfig.xml
I would like to send you zxp.
How about sending my Creative Cloud Assets link to your email?
Adobe Employee ,
Nov 16, 2016 Nov 16, 2016
Sure; b b b  at adobe dot com
I posted the zxp.
Thank you.
Adobe Employee ,
I received it, and I too get an installation failure; -411, compatible app not found.
Could you change this line, build a new .zxp, and see whether it helps?
Old:
<Host Name="PPRO" Version="[7.0,11.0]" />
New:
<Host Name="PPRO" Version="7.0" />
I tried based on advice from you.
However, ExManCmd execution result was -403.
The figure below is the command prompt in windows of my PC.
Just to be sure, i will send zxp to you.
