Hi - I need to copy and paste text from a pdf I'm working with. The document is not protected. The cursor covers three lines. When I attempt to copy and paste I get gibberish. I'm unable to use OCR because the document contains renderable text. I'm using Acrobat X Pro on Windows 7. The document version is 1.7 (Acrobat 8.x). The document procedure is Acrobat 10.1.16 Page Capture Plug-in.
Thanks, Supriya. I solved this myself, no thanks to Adobe's nonexistent "support". All that was required was printing and saving with Adobe PDF printer.
Hi Josephm90989622,
Request you to share the file on which you are getting this issue so that I can try reproducing the same at my end.
Please check the private message I ma sending you to share the information.
Supriya
