After upgrading to InDesign CC 2017 Mac Sierra, we are having a problem with the paragraph window.
After marking a tekst paragraph that needs an indent, then choosing the paragraph window marking the left indent, entering the number 3, the
focus shifts back to the tekst paragraph and replaces my tekst with the number 3.
That is not how the program normally works!
It seems as InDesign has a problem with where the focus is.
Anybody having a solution to my problem????
Finn Bonnesen
TEKNIQ
Denmark
pl2017 Did you try disabling Type Contextual Controls in the meantime?
Hi Finn,
We are aware about the issue you have mentioned and it is getting investigated.
As a workaround, you can turn OFF the "Show Adornment on Text Selection/Text Frame for more Type controls" preference from the Advanced Type Preferences.
Let us know if you need any further help around this.
Regards
Pragya Kandari
InDesign Engineering Team
Hi. I upgraded to the cc2017 indesign version but there are problems with the paragraph box. So ... I select a text .... then in paragraph window write a value that I want to change ... but as I press the "ENTER" key the selected text is deleted and in its place is written the number I had written in the window! The problem is very serious!
Yes, it is, and as per the response above from Adobe Staff member, Pragya Kandari, Adobe is aware of the issue and is working on it. In the meantime, I would suggest using either the arrows to the left of the text values in the Paragraph panel, or ¶ view of the Control panel.
I'm having the same issue. Hope it gets resolved soon.
great ... thanks
Yes I did. Thank you!
Thank you Pragya for the workaround that works. I am running El Capitan also, for everyone's reference. However I can't help but also agree with OL_Tonic's comment from December 18 which I paste here:
The work around seems to work so far. (turn off 'show adornment in advanced type). Why does Adobe feel it necessary to keep clogging the software with additions and updates, when it is affecting the basic functions of the software. just want to get my work done!!
There are countless users out there who are going to get angry and frustrated in trying to make simple changes/adjustments, along with being pressed for time, before doing a proper search as I did to fix this problem. Please, Adobe staff, in future be mindful to not mess up the simple things as you go ahead with your add-ons to products.
Hi All,
A solution for this issue is provided at Troubleshoot text selection issues. Please try the steps mentioned in the link.
Also, let me know of your feedback.
Monica Singh
InDesign Team
Error... Plugin is from an identified developer. However, it does seem to solve the issue for me.
Hi, I did what you said with the copyplugin that I downloaded from the link that you put but it did not work at all, I also did everything that in this forum is posted but didn't work either.
I NEED please this problem solved I can't do anything.
Did you try disabling the Type Contextual Controls in Preferences > Advanced Type?
Thanks - the plugin worked for me.
Has this fix been applied to the latest version of InDesign as downloaded through creative cloud?
Agree, huge problem with this not working properly. The workout turning off preferences works for now. Using the up/down arrows works sometimes. Please fix asap!!!!
InDesign CC 2017 not being able to identify that the paragraph text pallet has been activated by my mouse click is very serious! Approved copyrighted text can be deleted or changed while formatting it!! We as a business use Adobe InDesign all day. A FIX IS NEEDED - and FAST!!!
Absolutely true, bretth28998244. In the meantime, did you try disabling Type Contextual Controls so that you can get your work done?
I hope this is a very high priority for Adobe. Any designer worth their salt uses Paragraph spacing like we use em dashes and en dashes. It is critical to our work. I cannot tell you how much time this cost me on a recent project, and how risky it was that I could accidentally completely replace my text with something like "0p3". This is a very serious issue, and it's astonishing to me that it wasn't tested before this version was released. Adobe is charging us a fortune each month, most of us solo freelancers for whom the Creative Cloud fees are financially back-breaking. We deserve a thoroughly vetted product. Adobe should be embarrassed that something as basic as the Paragraph palette has such a fundamental flaw.
Hi Greenpoint​:
Thank you for your feedback. I know that Adobe has acknowledged this as an issue, and is working on it. In the meantime, did you try disabling the Type Contextual Controls? For many people, this solves the issue. I think the Contextual Controls are cool (and they work fine on my system) but not using them until this is worked out isn't a deal breaker for most of us. We still have the glyphs panel to access those characters.
Thank you so much for the workaround. I just installed the Indesign upgrade (I usually wait so I don't have problems with bugs - looks like I didnt wait long enough for this one). I am NOT running Sierra and I still had this issue. A little disconcerting to hear that this has been going on since November - but the fix worked for me for now. Using the little arrows was going to add considerable time to each project.
Thanks again for the detailed workaround including screen shots. Got me up and running quickly.
Insane issue. I am more particular then using the up and down arrows and am not going to spend all day when i know exactly what i want. Don't release upgrades if you can't have the simple functions work. Even with the "work around" you mentioned, there are still major issues with the cursor in that particular paragraph window.
