InDesign Script to Update Link Path
Nov 16, 2016 Nov 16, 2016
We recently copied all files to a new server. If I open indd files on the new server, they all link to the old locations since InDesign links from a root level. Is there an easy script I can run to change the beginning of the path?
The old path to a file is:
\\mhuc126\departments\Public Relations\Jason\Projects\Newsletters\image1.jpg
The new path is:
Since the file structure from "Jason" down stays the same, I only need to change "\\mhuc126\departments\Public Relations\" to "\\mhuc401\PR_MKT$\"
Can someone help with a simple script I can run after opening the document in the new location to update all linked files?
Scripting
3.8K
Guru , Nov 16, 2016 Nov 16, 2016
Here's my Restore broken links after server migration in InDesign script. However some people say it works for them, some say it doesn't: maybe it needs some adjusting to your particular server.
— Kas
Guide ,
I think no need to script for this..
JUST DELETE THE OLD LINK FOLDER.. SO WHEN YOU OPEN THE DOCUMENT IN THE NEW SERVER IT SHOW AS MISSING LINKS.. THEN YOU RELINK THE LINKS WITH NEW SERVER FOLDER..
HTH
K
Nov 17, 2016 Nov 17, 2016
, Thanks but that would be very time consuming. We have files linked in many different buried folder structures with literally thousands of InDesign files that need updated.
Kasyan Servetsky, Thank you so much! Your script is exactly what I was looking for and did the trick perfectly! I really appreciate it.
Guide ,
Hi Hollback...
Please mark as correct answer to Kasyan.. So only it honored the script provider..
K
Guru ,
— Kas
Nov 27, 2019 Nov 27, 2019
Can you paste the script in this forum.
The link is not working.
Heather 😄
Hi Heather,
here Kasyan's scripts overview:
http://kasyan.ho.com.ua/personal/my_scripts.html
The one you want to download should be listed there.
Uwe Laubender
( ACP )
May 10, 2020 May 10, 2020
Hi, can someone paste the script here as the links are all not working. Thank you so much in advance!
May 11, 2020 May 11, 2020
Kasyan's address for the website changed to:
http://kasyan.ho.ua/
Uwe Laubender
( ACP )
