Show amout of characters or Text frames under certain PT size say 4PT?
Advocate ,
Nov 16, 2016 Nov 16, 2016
Basically I am looking to find any text frame that the font is under 4PT.
Scripting
345
Guide , Nov 16, 2016 Nov 16, 2016
Hi.. Try this.. For now i just used Black color.. if you need use any other special color you have
var mycharacter = app.activeDocument.stories.everyItem().characters.everyItem().getElements();
var myarray=[]
    for (a=0; a<mycharacter.length; a++)
        if (mycharacter.pointSize < 4)
        myarray.push(mycharacter.length)
//~         mycharacter.parentTextFrames[0].fillColor="Black"; //Turn this if you need to fill the texrframes with color
        mycharacter.fillColor="Black";
Guide ,
var myarray=[]
alert("Total characters below 4 point is:\n"+myarray.length+"\n\n"+"And now it changed to Black color")
HTH
K
Advocate ,
Nov 17, 2016 Nov 17, 2016
Yes this works.  Thank you..  I've tried to modify this to get rid of the Fill after the font is fixed and its not working.  Can you See what i've done wrong?
var myarray=[]
        mycharacter.parentTextFrames[0].fillColor="Cyan";
        mycharacter.fillColor="Cyan";
            }else{
                if(mycharacter.constructor.name == "TextFrame"){
                    if(mycharacter.fillColor.name == "Cyan"){
                        mycharacter.fillColor = "None";
Guide ,
You forgot to include loop increment..
var myarray=[]
            }else{
this also works..
mypointsize();
function mypointsize(){
var myarray=[]
        if (mycharacter.pointSize < 4)  {
        //alert("s")
        else{return;  }
HTH
K
Advocate ,
When i Try these they only half work.  It does Make the Text frame cyan.  BUt when i correct the font size to 4PT or higher and rerun the script the Text frame still stays Cyan instead of "None".
Guide ,
Nov 21, 2016 Nov 21, 2016
HI..
If you correct the font size to 4 and still got error means use like..
if (mycharacter.pointSize <= 4)
Advocate ,
Nov 22, 2016 Nov 22, 2016
Thank you for all your help.  I used the below.  If the FOnt is 3.9999 or lower it turns Cyan.  And if the font is 4 or higher it makes it a None fill.
    var myarray=[]
            if (mycharacter.pointSize <= 3.9999)
           // mycharacter.fillColor="Cyan";
}else{
//     mycharacter.fillColor = "None";
            if (mycharacter.pointSize >= 4)
mycharacter.parentTextFrames[0].fillColor="None";
           // mycharacter.fillColor="None";
}else{
if(mycharacter.fillColor.name == "None"){
