when exporting from AE (video 720p) to Media Encoder the match source option scales down to 180p. When i uncheck the match source option and imput 720p the video is very bad quality.
[Moved to After Effects]
there is a bug in the current version of Ae CC 2017 that causes the dynamic link to take the resolution from the composition pop up resolution. the workaround is to set it to full before you send your comp to AME
or use the Queue in AME option in the render queue which is a better way to export to AME anyway since it keeps your render settings.
There is a bug fix update coming "very soon" according to Adobe folks, but I don't know if it includes the fix for this or not. Usually when they say an update is coming soon, it actually is on the way pretty quick. So, hopefully this little workaround won't be needed much longer.
Thanks so much.. I thought I was going crazy I re rendered at least 10 times...
The update is out, but this bug isn't one of the fixes that is in it. HOWEVER, this update seems to be fixing some of the biggest issues people have had on Macs ever since the initial CC 2015 release, so y'all should still get it!
