Mon C4D Lite ne synchronise pas ma camera après un suivi camera dans after effect!!!
J'ai tenté plusieurs méthode mais quand j'arrive dans le C4D avec mon document exporté il n'y a rien qui ce passe quand j'appuie sur play!
Comment résoudre ce problème?
Please describe your workflow in more detail - pictures would be helpful.
Also, please tell us all about your computer system. What version of After Effects are you using (down to the last version number)? What operating system?
My computer is a Imac 27inch(5k) with 16g of Ram
Processor3,2
graf card: amd radeon( 2048Mo)
system el capitan
after effect cc 2017.
C4D lite R16.
i did the camera tracking then create the solide+create my camera.(i put the solide on the ground)
Then i correctly export C4d sequence
i openened the C4d sequence in AE
then i go to modify original.
when i arrived in c4d i see the solide on the good place but nothing move when ibpush play!
when i try to put the same camera on C4D, nothing happen too!!! This not the first time i try
