Best place for JSX files shared across multiple products
Nov 17, 2016 Nov 17, 2016
Hi all, I was wondering what's the best option for shared tools over multiple Adobe products?
Example:  I have a polyfill script which extends extendscript built in objects that I'd like automatically loaded in Photoshop, Illustrator, Premiere and After Effects before any panel code is executed.
1. Make a silent panel which registers a bunch of functions, classes etc on startup.  If so how can I determine panel load order?
2. Put a jsx file somewhere in C:\Program Files (x86)\Common Files\Adobe
3. C:\Program Files\Common Files\Adobe\Startup Scripts CC.  Still working out if this is an option...
4. ?
Geordie
Actions and scripting
1.9K
Adobe
Participant ,
Hey geordiem74078114​, You can place your JSX file in your Adobe Scripts folder. You can actually put it wherever you want, but this is a folder that is created when you install an Adobe product (it might just be photoshop?).
~/Documents/Adobe Scripts/
You can then include that file in any script that you're building by adding this line at the beginning of your code
#include "~/Documents/Adobe Scripts/script.jsx"
#include is similar to a require in JavaScript. After you include your file, you will be able to use its functions.
Hope that helps.
I only use Photoshop but I have many versions of Photoshop installed. All versions of Photoshop  use the same copy of the scripts I add to Photoshop.    I Install Scripts I add into a Photoshop Scripts tree on my C: drive and I link all Photoshop versions installed Presets\Scripts\ folder to my Photoshop scripts tree.   I use sub folders just to help me remember what is what.   When Photoshop starts up it scan the full tree and scripts are listed in menu File>Scripts and my Plug-in scripts are listed in menu File>Automate like the should be.
JJMack
Thanks guys, yeah I use a lot of includes but was wondering if there was an official way as I'd like to avoid executing the shared scripts every time something references it, but I can minimize that with some logic.
I found this in the Photoshop CC Scripting Guide:
"On startup, Photoshop executes all .jsx files that it finds in the startup folders.
➤ On Windows, the startup folder for user-defined scripts is: C:\Program Files\Common Files\Adobe\Startup Scripts CC\Adobe Photoshop
➤ On Mac OS, the startup folder for user-defined scripts is: ~/Library/Application Support/Adobe/Startup Scripts CC/Adobe Photoshop
If your script is in this main startup folder, it is also executed by all other Adobe Creative Suite 6 applications at startup."
I just tried adding a file here:
But it didn't seem to be executed by Photoshop or Premiere.
I think I'll set an environment variable in the install process with script paths and use $.getenv to access it
Adobe Employee ,
Nov 18, 2016 Nov 18, 2016
Which version of Photoshop? If CS6 then put them here as well: C:\Program Files (x86)\Common Files\Adobe\Startup Scripts CS6
Hi Tom, I actually want scripts to be loaded in Photoshop, Illustrator, Premiere and After Effects CC.  This is basic stuff like extending Object and String types in Extendscript.
Do you know if adding scripts here:
Should work as stated in the CC Scripting Guide?  I was looking at the CC guild but that particular part only mentions CS6.
Adobe Employee ,
You can do runtime checks for host app. I would use (x86) in Program files unless you are on a non 64 bit machine then it would be Program Files without the x86. That common location for 32 bit is used by the 64 bit apps. See the photoshop.jsx to see runtime choices we make to get them running in the correct application.
Dec 29, 2016 Dec 29, 2016
Hi Tom, thanks for your reply, not sure if we're on the same page, I basically want to put a single JSX file somewhere that's executed by All (well the basics like Photoshop, Illustrator, Premiere and AfterEffects) adobe products on startup.  My scenario is I'm creating CEP Panels for PPro and AfterEffects.  I have a JSX file which polyfills some parts of ECMAScript that I just want globally available.  I'm trying to avoid having code at the start of every different panel that checks for the upgrades.
If your script is in this main startup folder, it is also executed by  *** ALL *** other Adobe Creative Suite 6 applications at startup."
I've tried adding a jsx these these folders:
C:\Program Files (x86)\Common Files\Adobe\Startup Scripts CC
Basically from what the docs say that file should get executed by all adobe apps at startup, but it doesn't.
Back in the days of Flash panels you could have a shared library but not sure how to do the same thing with HTML panels.
