Hey,
I'm trying to export a sequence into a custom xml file and I'm currently trying to get the name of a track but I for the life of me can't figure out how. I thought that it would be in the PrSDKVideoSegmentProperties, but I can only get the TrackId from there. Nothing else.
Thanks for the help,
-anthony
Not a plug-in, but HTML5-based panels (which use PPro's ExtendScript API) can get all info about every clip in a sequence (and edit most of it).
The PProPanel sample's readme explains how to set up a panel dev environment.
From what code are you exporting; plug-in, or panel?
Export Controller Plug-In is what I am basing my code off of.
I don't know of any way to get track names from an Export Controller.
I'm curious; why would an Export Controller, which makes PPro render an entire sequence, care about track names?
Sorry it has been a while since I wrote the original plug-in. I believe I started with the export controller because it was the simplest looking SDK example, but I don't end up using the export controller suit. I mostly use the Video Segment Suite to parse the sequence and get as much of the data as I can out of it. Is there another plug-in that I can use that will give me the info I need?
