I'm running Lightroom 6.7 (not CC) on an iMac using Sierra and can't group selected images into stacks while in Library module. Cmd + G isn't working either. This action stopped working before updating to 6.7. Suggestions?
What error message do you get?
Are the images in the same folder?
I don't get any error message; nothing happens. Yes, they're in the same folder. Thanks for replying.
Try stacking with the menu command Photo > Stacking > Group Into Stack. If that works, then that indicates the problem is with the keyboard shortcut.
(Should I assume from your user name that you're running LR in English? There have recently been problems with keyboard shortcuts in other languages.)
John: I tried Photo>Stacking>Group into Stacks and had the same problem. Yes, I'm running in English.
Are you in a folder or in a dumb collection when you try Cmd G? You're not in a smart collection?
John: I'm in a regular folder--not a collection or smart collection.
At this point, I only have two suggestions:
1. Try resetting LR's preferences: http://www.lightroomforums.net/showthread.php?25197-Resetting-the-lightroom-preferences-file-updated That often fixes things when LR goes wonky (though I'm not so sure about your situation). But it's quick and easy to try.
2. If that doesn' help, post a full-resolution screenshot of your entire LR window, with the photos you're trying to stack selected. Maybe we'll see something we're all missing.
John: I've been out of town. I'll give your suggestions a try tonight or tomorrow and will do as your requested if it works. Thank you.
John: Please skip to the last paragraph.
I'm trying the reset the LR preferences file. However, as you can see from these three screenshots, I can't locate this file.
Top left screenshot is the path that the instructions say to follow, but it doesn't lead to a Library folder.
So, I tried getting there two other way, as shown on the next two screenshots, but they didn't work either.
BTW, when I installed LR I let it put folders/files where it wanted--I didn't specify any user-defined locations. Also I began having the problem of Grouping into Stacks not working a couple weeks ago when I was still using LR 6.0. That's when I decided to upgrade to LR 6.7.
I just went into LR to make a screenshot showing grouping of 4 images into a stack and it worked! So I tried it with several other folders of images, as they also worked. Why now, I have no idea. LR apparently performs self fixes when it sees its user trying (but failing) to reset preferences. I guess I'll just post something like "Problem resolved itself" on the forum--unless you have a better idea.
Thanks for trying to help.
Sometimes simply restarting LR, or rebooting your computer, can fix intermittent problems.
I think you were looking at reset instructions for earlier versions of LR. LR 6 lets you hold down a couple of keys when you start it -- you don't need to find any system files; see the section "Resetting the Preferences File – Lightroom 6/CC only": http://www.lightroomforums.net/showthread.php?25197-Resetting-the-lightroom-preferences-file-updated
