In After Effects CC 2017, It does not support .AEC files generated from Cinema 4D. How can i go back to a previous version? Thanks.
Just view previous versions in the CC app. This topic has been discussed dozens of times in this forum and it's in the help files for the CC app. If you can't find the option in the CC app then try searching the forums.
It is not in there. Should i uninstall first? Or would i lose all my plugins?
are you using a paid subscription for after effects? because trial won't let you use older versions. if you are a CC Paid subscriber try reading through here:Download and install Creative Cloud apps
I do not think this is an issue with the current version of After Effects. To read an AEC file, you probably need to install the plugin from MAXON.
