Ich habe Muse CC (2017) auf meinem Mac installiert. Nun erhalte ich beim Versuch eine bestehende Muse-Datei zu öffnen immer die Fehlermeldung "Error #3125".
Ich benötige dringend eine Lösung!!!!
Hello Everyone,
Could you please try downloading our next Muse prerelease build and check if you are getting the same issue.
To download the new prerelease build go to - https://museprerelease.com
Ankush
anch'io ho lo stesso problema. Qualsiasi file muse che apro mi da questo errore!!! come faccio per risolvere il problema???
aspetto una vostra celere risposta!
ne ho davvero bisogno... grazie e buon lavoro
Bei mir dasselbe. Es passiert erst, wenn man Muse 2017 beendet und dann das Programm startet und die Datei öffnen will. Da scheint das schreiben in die Datenbank buggy zu sein. Da sollte Adobe asap ein upgrade bereitstellen!
Hello Everyone,
Ankush
Same issue in both old, new and prerelease version - cannot open document!! Ohnooo this really makes me cry - i worked so hard
Danke für den Link. Aber da komme ich nicht weiter.
Hi Ute,
Can you please post the snapshot of the error message here, so that we can look into it.
Kratika
Any help?? We need to update our site!!
Hello Everyone,
we are thoroughly investigating this issue, and need your help in identifying the root cause.
It is been noticed that this issue is coming across majorly in a non-English environment.
Could you all please let us know the platform (Operating System) you are on and is it a file specific issue?
Are you guys able to work on a brand new file?
Could you all please send your .muse files which are triggering this error on my email ankrao(at)adobe(dot)com?
Ankush
Hello Ankush,
I'm working on a mac. My files are based on a PC in the network. On the PC there is a dropbox working, syncing the webfiles. Muse always hang up when saving files while the dropbox is working. So I have to stop the dropbox when working with muse.
When I open a file and get the #3125-Error, I make a copy of it and I can work with this duplicate. Interesting: Now I can open the original file, too. When closing Muse, both files will produce the same error. Also interesting: Opening these files on an other mac or pc will not produce the error, I can work, make changes and save the file as nothing happend. But back on my own workstation the files still have the error. Next I tried to rename these files and: The error does NOT appear. Saving it once again, does not make the error. But closing Muse does. After starting muse all these files can't be open.
Hope this helps.
Kind regards
Andreas
Hello Ankush, hi Andi,
same to me (open, re-open, re-name always the same with error #3125 etc.) / i work on mac OS X El Capitan Version 10.11.6, but files based on my system, no pc involved, they are created on my workstation only.
i will switch to mac os sierra now...
Please let us know, need your help!
Best regards
sandra
i switched to macOSSierra....it runs...! I will let you know if this is the answer for our problem...or if it will appear again!
best regards
Sandra
Hi ,
Please follow below steps and let us know the results:
1) Make a new folder on the network drive and place the .muse files there, try opening the file from their , did it run correctly the first time? now quit Muse and try opening that file again, so did the Error #3119 or Error #3125 starts coming from second time you open the same file again?
Kratika
Good Morning,
I have the same problem when opening the muse file (Error #3125). Operating system Mac OS x 10.11.6, lates Muse version CC2017.0.
I copied the muse file to another destinantion (from network folder to local folder). Then I could open the file.
Another solution: I opened first an "old" fuse file (not saved with the CC2017.0 version). Then I could open the other files created with the CC2017.0 version.
Allthough it would be helpful for the working process if Adobe could fix this problem 🙂
Kind regards
Florian
Guten Morgen,
leider hat der switch auf Sierra nur temporär geholfen und auch nach dem update auf die neueste muse-Version lassen sich die alten Dateien nicht öffnen. Wieso kümmert sich das adobe-Team nicht um diese Problem?
Beste Grüße
Sandra
Hallo zusammen,
gleiches bei mir / über einen Umweg dann auf die Seite gekommen und die Prerelease-Version aufgespielt mit dem selben Ergebnis: immer noch error #3125 ! 😞 !!!
Bitte ändert das schnellstmöglich - schließlich müssen die websiten, die schon online sind, auch mal upgedatet werden.
Please see thread Re: Muse Loading Error #3125 this issue is resolved for many users with Latest Muse Prerelease.
muse 2014.2 crashes - then corrupts file - will not reopen - all work LOST!
could you please let me know steps to reproduce the issue, and help me know if it is a different issue from the one mentioned in thread Re: Muse Loading Error #3125
Re: Muse crash after update 2017
Kratika
Ich habe folgenden Tip aus einer anderen Frage angwendet: 1) alle Unterstriche und Bindestriche im Dateinamen entfernt.
2) Datei in der Prerelease-Versiuon geöffnet und geschlossen.
3) Nach dem Schließen und erneutem Versuch die Datei zu öffnen erhalte ich den Fehler #3119.
Sehr schlecht! Und nun?
Hi Sandra,
Please see Re: Error 3119 in Adobe Muse 2017
Re: This Adobe Muse site cannot be opened. Error #3119
Kratika
anche a me da lo stesso errore con la prerelease!
Se riesco ad aprire un solo file muse (vecchio) poi riesco ad aprire qualsiasi altro file! devo andare a tentativi... è snervante!
