Problem in Right Indent Tab with a dot leader setted
Nov 21, 2016 Nov 21, 2016
I created a TOC using right indent tab and also a dot leader for the number flush right. It is fine in CC2015. However when upgraded to CC2017, it freeze when I using the Type tool to select the text. (It stopped right at the beginning of the right indent tab). Now I changed to "normal tab" instead of "right indent tab".
Does anyone know how to fix it?
Spec: inDesign CC2017, Window 7 64bit
2.4K
Adobe Employee , Nov 21, 2016 Nov 21, 2016
If possible can you please mail me your document so  that we can look into the tabs issue that you are facing?
Also as a workaround you can try the following:
Navigate to Preference->Advance Type -> Type Contextual Controls and disable the first preference “show for Character Alternates, Fractions, Ordinals and Ligatures”
Let me know if this helps
Thanks and regards,
Aman
amaarora@adobe.com
InDesign Engineering Team
Adobe Employee ,
Thanks and regards,
Aman
amaarora@adobe.com
Hi Aman,
Thanks for you help. As you mentioned, I disabled *“show for Character
Alternates, Fractions, Ordinals and Ligatures” and it fixed the problem!
(Although I have no idea what this stand for)*
*Attached there is the sample indd for you. BTW the problem only happened
both "right indent tab" and "dot leader" are used.*
aper.cc01
Mar 07, 2017 Mar 07, 2017
Thank you so much, this problem has been driving us crazy here. This work around seems to be working. Can anyone tell me if there are any "unintended consequences" for this fix? I haven't seen any so far that I know of.
P.S. If you would like samples of problem files, I can send you literally hundreds. We do labels with active ingredient statements that utilize dot leaders and FR tabs every time, so I have plenty to share.
Adobe Employee ,
Mar 08, 2017 Mar 08, 2017
Mandolynda​: there are no consequences other than the fact that you wont be able to use the OpenType enhancements introduced in InDesign CC2017. You can read more about it here New features summary for the 2017 release of InDesign CC
And off course you can mail me some documents wherein you are facing this issue
Aman
amaarora@adobe.com
Nov 30, 2016 Nov 30, 2016
I have the same problem exactly, since the last Indesign upgrade. Have many cases where selecting text brings up the beachball, but with Right Indent Tab with a dot leader it freezes completely when I try to select it.
I've been having this problem too! it is so aggravating. Any ideas on how to fix it or is it an indesign bug? I thought I was doing something wrong.
parcea, Did you disable Type Contextual Controls as stated earlier in the thread?
Sep 18, 2017 Sep 18, 2017
It's still not working.
