2
AEGP Plugin CINEWARE SceneLayer: CINERENDER - Connection failure (5027 :: 12)
Oct 27, 2014 Oct 27, 2014
Working in AE CC2014.1 and C4D lite.  I have a project with a few .c4d files in it.  I'm working on this project at my work computer, and I then bring it home in the evenings and work on it on my own computer (both mac pros).  At work it's fine, at home I have problems.
I get the error "AEGP Plugin CINEWARE SceneLayer: CINERENDER - Connection failure (5027 :: 12)" when I launch AE, and I think it does this for every .c4d file I have in this project.  I can see the file just fine in C4D lite, and in after effects I see a black screen in the comp window.  However I can see the thumbnail of the c4d file in the project window when I have the c4d file selected.  The layer is active in the comp's timeline as well.  Not sure what to do about this.  Any ideas?  Thanks.
Work Computer:
Mac Pro 5,1 2x6 core
Quadro 4000
64 GB Ram
Home Computer
Mac Pro 3,1 2x4 core
GTX 680
14 GB Ram
Error or problem
56.5K
New Here , Feb 14, 2015 Feb 14, 2015
Hey all,
I resolved the problem by running AE as the administrator. Right click on the program and run as administrator. This is using Windows 8.1
ARe your C4D and AE versions the same? Have you checked the port connection options in Cineware?
Mylenium
Oct 28, 2014 Oct 28, 2014
Hi Mylenium.  Thanks for the reply.  They are the same versions as far as I know - CC 2014.1 and C4d r16 (CC updates and all).  But I am relatively new to C4D, and I don't really know anything about port connection options.  I'll do a google search for that, but if you have a link, it would be greatly appreciated.
Nov 18, 2014 Nov 18, 2014
I've been running into this exact problem on projects that feature many c4d files in them that were originally produced on my previous copies of Adobe After Effects CC...
The minute I updated CC to CC2014 it happened every once in a while and by simply restarting or just purging all my memory..and the error didnt pop up the next time i open the project.
Now that I've updated CC2014 to the new blue look (13.1.1) this error is constantly occuring when opening AEPs built in the original CC (or version 12)
I've checked the cineware options and this is the current setup for the C4D render path
C:\Program Files\Adobe\Adobe After Effects CC 2014\Support Files\Plug-ins\MAXON CINEWARE AE\(CINEWARE Support)\bin\CineWare.exe
the C4D executable path is
and its using the TCP port of 5030
it's worth noting that if I open a blank project..create a NEW maxon file..open cinema4d Lite..then close the AE project..leave C4dLite up and open the older CC AEP..it opens up the project without issue.
This is because I have C4D Lite running in the background.  without it..i would've run into the same SceneLayer error.
Dec 04, 2014 Dec 04, 2014
I am having this same exact issue.  I'm guessing Adobe hasn't found a proper solution yet?
Dec 19, 2014 Dec 19, 2014
I've been getting this quite often as well. Almost reason enough to just buy Cinema 4D outright even though all I need is it to work within AE.
Jan 09, 2015 Jan 09, 2015
Haven't you fixed this ??. I get the same issue
Feb 06, 2015 Feb 06, 2015
I have the exact same issue. Has anyone figured out how to get around it? I'd really appreciate the help.
Hey all,
Feb 19, 2015 Feb 19, 2015
Thaks mattt48180508  it worked!! you saved my life
Apr 06, 2015 Apr 06, 2015
Thanks, That was my problem too.
Apr 07, 2015 Apr 07, 2015
I'm using WIN 7  64 bit and running the program as administrator has reopened AE with the c4d pjt file  OK. Hope this solves it, but obviously some bug that needs to be fixed. Thanks.
Mar 25, 2016 Mar 25, 2016
Running AE as admin fixed the problem for me.. Thanks for the tip
Mar 26, 2015 Mar 26, 2015
I am having this problem in my MAC.  What is my solution?
Participant ,
I have the same problem  (PC win 7).
Thanks for the solution but it is not a final solution: I often start Ae by clicking on the *.aep file and in this case, it does'nt work.
Adobe has to correct that!
Just started getting this problem... "cineware closethread" etc. yesterday after working on a tutorial course for the past couple of days with no problem. Then it started when opening a the project again with the c4d file in it.
Participant ,
Apr 08, 2015 Apr 08, 2015
It seems that the problem comes from TCP... Only change the CINEWARE TCP port
A solution: CreativeCOW
It's OK for me.
Jul 18, 2016 Jul 18, 2016
I had this same issue but only on certain cinema 4d files. Some worked some didnt. Turned out it was an FDD deformer in the scene that was stopping it importing. Maybe a solution to some of the people here. As running as admin didn't work for me.
Jul 23, 2016 Jul 23, 2016
Installing and using CC 2015.3 (After Effects version 13.8) should solve the FFD problem. It did for this person.
Nov 21, 2016 Nov 21, 2016
[EXPLETIVE DELETED] YES! after everything I have tried running the program as admin worked... I can't believe after hours of work on this problem this simple approach is all it took.
Jan 25, 2017 Jan 25, 2017
THANKYYY YOU! Your tip is perfect. It worked
Feb 05, 2017 Feb 05, 2017
Thank you, I run AE as admin and solved the problem. Windows 10.
Apr 25, 2017 Apr 25, 2017
Hey Adobe/Maxon, We need to talk about this...
These fix's only work on personal machines where you are administrator or where you can readily change ports.
I work at a large corporation, I am not the administrator, I will not be able to get an administrator to stop by every morning, or after every crash
I cannot open new ports as almost every port in my office is closed by corp security.  I cannot surf 4/5ths of the internet, check any mail, update my applications or, as it seems now, run files that once worked.
I will add tot he confusion by saying I DELETED the C4D footage/File, reduced my file, imported into a new AE File, and I STILL GET THE ERROR.  No Cinema 4D what so ever.  I literally have 1 audio file, and 2 solids in my bin and I STILL GET THE ERROR!!!
Mar 13, 2018 Mar 13, 2018
C4D R19, full version, DOES NOT work with AE live link. Period.
Adobe blames C4D.
C4D blames Apple.
Apple blames Adobe.
Any issue you solve brings you to another issue.
Save your money and use Blackmagic Fusion, Houdini, Maya or Blender instead.
Mar 27, 2020 Mar 27, 2020
Вобщем решил проблемму , единственное что помогло это другая версия After Effects установленная в тот каталог куда именно ей хочется , ничего не менял. Помог Diakov. Widows 10
