Space before/after for placed text with hard
Engaged ,
Nov 21, 2016 Nov 21, 2016
What is the best way to handle placed text that looks like:
Page: 1
Title: This is the title
Date: 2016
Artist: John Doe
Credit: John Doe
Source: https://site.com/
http://site.com/x
Page: 2
Date: 2016
Artist: John Doe
Credit: John Doe
http://site.com/x
Page: 3
Date: 2016
Artist: John Doe
Credit: John Doe
http://site.com/x
I am placing this text into a 3-column layout master frame, so the text spans all columns and multiple pages.
I am trying to avoid spacing issues by using "space after" (or "before").
Unfortunately, when placed, I get this:
I would like my text to look like this (after being placed):
In the screen shot directly above, in order to get the related text bits to group together, I had to manually insert a "Forced Line Break" (Shift + Return) between the lines of related text.
Note that my paragraph style, for both screenshots above, uses space after to control paragraph spacing:
Question(s):
Is it possible for me to place the above text and have it look like the last screen shot as seen above?
If so, how?
From what I can tell, other than using a tagged text file (which I would like to avoid), I'll have to do some find/replace regex work on the placed text in order to get the results I want?
Any tips would be appreciated.
455
Guide , Nov 22, 2016 Nov 22, 2016
Hi
There are many ways to achieve what you want. This is the one I would use:
First, make sure you don't use double line breaks nor forced-returns.
Then, create two paragraph styles: i.e. "normal" and "1st line".
Set up "normal" style without space after/before.
If you want it aligned on baseline grid, make sure baseline grid leading is set to - at least - the same leading value as your paragraph style. Note: this explains why leading "looks" so big your first screenshot. Choose "View > Grids & Guide
Guide ,
Is it you using only one paragraph style?
Engaged ,
Nov 25, 2016 Nov 25, 2016
Hi Tpk1982, thanks so much for the reply, I really appreciate the help.
Yep, just one paragraph style so far. The bold parts are grep styles and I have the baseline grid setup.
With that said, it looks like vinny38​'s suggestion will work pretty good!
Seems like I won't be able to avoid doing a find/replace unless I head the tagged text route? Thankfully find/replace is quick, and I can save the searches to make it even easier, so I think that's going to work well for my workflow.
Thanks again to both of you for the help!
I'll be back soon to report my findings.
Guide ,
Hi
If you want it aligned on baseline grid, make sure baseline grid leading is set to - at least - the same leading value as your paragraph style. Note: this explains why leading "looks" so big your first screenshot. Choose "View > Grids & Guides > Show/Hide Baseline Grid" for a better understanding.
Tip: you might want to use GREP in order to set "Page:", "Title:" etc. to bold
Then, set up "1st Line" paragraph style with a space before (any would do if aligned on baseline grid).
Finally, use a simple search/replace in order to apply "1st line" par. style to all paragraphs including "page" text:
Tip: Use Keep option in order to avoid "Page: x" to stand alone at the bottom of a column
You're done.
As I said before, this is one method, not the only one. (I don't like forced-returns, but you could also use them, using another method based on single paragraphs > Better if you want to avoid breaking)
Hope that helps
Regards
Engaged ,
vinny38 wrote:
Hi
There are many ways to achieve what you want. This is the one I would use: <snip>
Thanks so much Vinny! I really appreciate the help.
I am trying your suggestions now and will report back my findings (looks like it's going to work pretty well).
Thanks much!!!
Engaged ,
That worked really well! Thank you vinny38​! I really appreciate the help!
The only change I made was to use Grep for the search as it ended up being much faster:
