List of reduced or increased images with value
Engaged ,
Nov 16, 2016 Nov 16, 2016
Can anyone modify jongware script below:
I need only those image list which is reduced or increase image size with percentage value but this script get all the image with percentage value. I do not need which image is 100%.
app.activeDocument.viewPreferences.rulerOrigin = RulerOrigin.PAGE_ORIGIN;
list = [];
imgs = app.activeDocument.allGraphics;
unitname = getCurrentUnit();
for (i=0; i<imgs.length; i++)
scale = roundMe(imgs.horizontalScale,1);
// some fair rounding
list.push (imgs.itemLink.name+'\t'+scale+'%');
// alert (list.join('\r')); exit();
defaultFile = new File (Folder.myDocuments+"/"+app.activeDocument.name.replace(/\.indd$/i, '')+".xls");
if (File.fs == "Windows")
writeFile = defaultFile.saveDlg( 'Save report', "Plain text file:*.txt;All files:*.*" );
else
writeFile = defaultFile.saveDlg('Save report');
if (writeFile != null)
if (writeFile.open("w"))
  writeFile.encoding = "utf8";
  writeFile.write (list.join("\r")+"\r");
  writeFile.close();
function roundMe(val,to)
var t = 1;
while (to-- > 0) t *= 10;
return Math.round(val*t)/t;
function getCurrentUnit ()
switch (app.activeDocument.viewPreferences.horizontalMeasurementUnits)
  case MeasurementUnits.POINTS: return "pt";
  case MeasurementUnits.PICAS: return "pt";
  case MeasurementUnits.INCHES: return "in";
  case MeasurementUnits.INCHES_DECIMAL: return "in";
  case MeasurementUnits.MILLIMETERS: return "mm";
  case MeasurementUnits.CENTIMETERS: return "cm";
  case MeasurementUnits.CICEROS: return "c";
  case MeasurementUnits.AGATES: return "ag";
  default: alert ("Oh, come on!"); exit(0);
Sumit
-Sumit
Scripting
1.3K
Guide , Nov 17, 2016 Nov 17, 2016
Hi Sumit,
Here is the version with vertical scale value..
list = [];
vscale = roundMe(imgs.verticalScale,1);
if((imgs.horizontalScale!=100) ||(imgs.verticalScale!=100)){
list.push (imgs.itemLink.name+'\t'+scale+'%'+'\t'+vscale+'%'); }
// ale
Guide ,
Simply add a if condition in line 9.. it will work now
list = [];
if(imgs.horizontalScale!=100){
list.push (imgs.itemLink.name+'\t'+scale+'%'); }
else
  writeFile.close();
var t = 1;
Engaged ,
Thank you so much!
-Sumit
Don't forget that there is also a vertical scale value.
And that could be a different to the horizontal one.
And how about skewd images?
( shearAngle )
Uwe
Engaged ,
Thank you Laubender,
Yes, you are right.
Can you do that?
Kind Regards,
Sumit
-Sumit
Engaged ,
Dear TPK,
Can you help me?
How to right in this forum as a script format as you write?
Kind Regards,
Sumit
-Sumit
Guide ,
Hi Sumit,
list = [];
else
  writeFile.close();
var t = 1;
Guide ,
For script format.. use like below
Engaged ,
Thank you so much!
-Sumit
Engaged ,
Nov 22, 2016 Nov 22, 2016
Dear TPK,
Can I open, save report automatically?
Sumit
-Sumit
Guide ,
like below?
list = [];
defaultFile = new File (app.activeDocument.name.replace(/\.indd$/i, '')+".xls");
if (defaultFile.open("w"))
  defaultFile.encoding = "utf8";
  defaultFile.write (list.join("\r")+"\r");
  defaultFile.close();
  defaultFile.execute();
var t = 1;
Engaged ,
Dear TPK,
Works fine but need to save report at Desktop also.
Sumit
-Sumit
Guide ,
Change line 15 to..
var defaultFile = new File("~/Desktop/Report.xls");
Guide ,
or..
var defaultFile = new File("~/Desktop/"+app.activeDocument.name.replace(/\.indd$/i, '')+".xls");
Engaged ,
Dear TPK,
If you do not mind, can I ask your name please?
Both of your comment is file save only, not opening automatically.
Sumit
-Sumit
Guide ,
HI Sumit,
My name is Karthi.
Using    defaultFile.execute();  is to open the xls file automatically after you ran the script...
Just close the excel and try again
Engaged ,
Dear Karthi,
Thank you so much!
I appreciated your reply.
I have used below script:
list = [];
var fName = app.activeDocument.name.replace(/\.indd$/i, '')+".txt";
defaultFile = new File ("~/Desktop/"+fName);
var t = 1;
Sumit
-Sumit
Participant ,
Jul 03, 2018 Jul 03, 2018
Can I get height and width of graphic text frames which is not scaling 100% in our report?
Engaged ,
Nov 26, 2016 Nov 26, 2016
Dear Karthi,
When I use below line, that is not working.
Can you tell me what I am doing wrong?
if((imgs.horizontalScale!=100) ||(imgs.verticalScale!=100) || (imgs.imageTypeName != "PDF")){
If I use EPS or JPEG then working but When I use PDF then not working.
Sumit
-Sumit
Guide ,
Hi..
In your if condition you ignored the image type of PDF if comes.. So only you not get any results..try like below
if((imgs.imageTypeName == "PDF")){   \\ hope you know the difference of this != "PDF".. not sure why you check this
Engaged ,
Dear Karthi,
I do not want to reduced pdf list because, In my document I have used pdf as a mini in teacher edition.
Same condition working with eps, ai and jpeg but not working with pdf only.
Sumit
-Sumit
Guide ,
Nov 27, 2016 Nov 27, 2016
better try like
if(imgs.imageTypeName == "PDF"){continue;}
if((imgs.horizontalScale!=100) ||(imgs.verticalScale!=100){
also like below
if((imgs.horizontalScale!=100) ||(imgs.verticalScale!=100) || (imgs.imageTypeName != "Adobe PDF")){
or
if((imgs.horizontalScale!=100) ||(imgs.verticalScale!=100) || (imgs.imageTypeName !== "PDF")){
Engaged ,
Dear Karthi,
Thank you so much!
Today, I learned from you "PDF" is not working but "Adobe PDF" is working.
Below code working nicely.
But, Now problem is: Adobe PDF also escape .ai file. I need escape only .pdf file.
Regards
Sumit
-Sumit
Guide ,
HI..
this maybe a solution.. try and let me know
if(app.activeDocument.allGraphics.itemLink.name.match(/\.pdf$/i) != null) {continue;}
Engaged ,
Nov 28, 2016 Nov 28, 2016
Dear Karthi,
Yes, your code is working nicely.
You are great.
Thank you so much.
Sumit
-Sumit
