Do you guys see that really really long bar? I'm currently trying to make a lyric video on after effects. Everytime I put in a new word, it defaults to something that long, causing me to have to cut it down manually rather than have it naturally last for a short time, such as the other bars in that above picture. Is there some setting I can change so it doesn't default to that length? I'd like the default length upon insertion to be shorter.
All help is appreciated.
Thank you.
It works as it's designed to work. No way to change it.
Mylenium
Learn the keyboard shortcuts. Alt/Option + [ for in poin, Alt/Option +] for out.
you can change the default still footage duration (text included). under edit->preferences->import.
here I changed it to 4 seconds
and with un-checking the "create layers at composition start time" you can really speed up your workflow
now it behaves like this:
I keep forgetting about that... *lol*
Mylenium
happy to refresh your memory M
