Hi Dr. Pruiett
After you stop recording and enter the edit mode, do you see
mouse icons on the slides up and down the Film Strip on the left?
If so, you should be seeing Mouse Movement. If the icons aren't
there then something is amiss.
Well, I suppose something is amiss either way if you aren't
seeing mouse, eh? But it would be nice to know if you are even
getting the mouse icons. If you are, I suspect the movement may be
there, but something is preventing you from seeing what was
recorded as opposed to Captivate failing to record in the first
place.
Cheers... Rick
