Hey guys I'm pretty new to animate and I've got a pretty annoying problem using a classic or motion tween for a rotation. I drew an arm and a hand on different layers An wanted the arm to rotate together with the hand at first. That part worked fine by just selecting both parts and changing the pivot point for both at once. But after that tween I wanted the hand to move on it's own for the rest of the animation so I just added another tween and rotated it but that's where my problem occurred. For some reason the movie clip does not rotate around the pivot point I had set before.
Thanks in advance
check the pivot point (actually, transform point or registration point) in the keyframes that contains the problematic tween. if you use a motion tween, that should be the first keyframe only of the tweened hand.
Okay I got i just had to have the same registration point on both frames to make the tween work correctly.
Thank
