Dear friends,
It's quite easy to set up a new character format with 'all AsIs', but I have not found the necessary ingredients to set up one with particular properties:
a) name = superscript: all AsIs, but superscript
b) name = highlight: all AsIs, but a colour (from the standard set)
Hence I had the idea to call the Character Designer by means of F-codes.
Well - it opens, but I do not see how to set the dialogue to "All AsIs" - because the user normally has its cursor somewhere in the document and the really defined properties are only seen if the cursor is outside the document.
So far I'm here:
function DefineCharFmt (sName, oDoc, bProperty) {
var charFmt = 0, fcode = [], msg;
msg = "Character format '" + sName + "' does not exist in catalogue\nShall it be created?";
charFmt = oDoc.GetNamedCharFmt (sName);
if (!charFmt.ObjectValid()) { // does not exist in catalogue
if (confirm (msg, false, "Confirm new character format")) {
charFmt = oDoc.NewNamedObject (Constants.FO_CharFmt, sName);
if (bProperty) {
fcode[0] = FCodes.CHAR_DESIGN_CAT; // Open Charactr designer to set the property
// fcode[1] = FCodes.CHAR_DESIGNKIT_RESET; // nothing to do with Set AsIs
Fcodes(fcode);
return true;
} else {
return false;name
return true;
} //--- end DefineCharFmt
Maybe I need to put it the other way round:
Instruct the user that for the proper function of the script the xxx character formats must exist in the catalogue and be set up accordingly...
Or:
Createte the needed character formats in the catalogue - only "AsIs" and instruct the user to set them up properly to see the effect in the document.
Klaus
Hi Klaus,
Your approach with the color is not quite correct. You need this:
oColor = oDoc.GetNamedColor ("Salmon");
charFmt.UseColor = true;
charFmt.Color = oColor;
-Rick
Well, for the simple cases (only AsIs, AsIs + superscript) I'm succesful.
But defining a colour is not that easy:
#target framemaker
var oDoc = app.ActiveDoc, OK;
$.writeln (DefineCharFmt ("0-C", oDoc)); // AsIs + colour Salmonfunction DefineCharFmt (sName, oDoc) {
var charFmt = 0, oColor = new Object (Color);
charFmt = oDoc.NewNamedObject (Constants.FO_CharFmt, sName); // define new char format - all AsIs
oColor.ReservedColor = Constants.FV_COLOR_SALMON; // 1
charFmt.Color = oColor; // 2
LIne 07 creates the character format "all AsIs", to which I want to add only one property: a predefined colour.
At line 10 an inspection of the objects shows:
oColor.Name = Salmon; oColor.ReservedColor = 16
But line 12 reveals:
charFmt.Color.Name = null; charFmt.Color.ReservedColor = 0
What is missing here?
Thanks for Your help
Klaus
Hi Klaus,
-Rick
Thank You Rick - this works.
Anidea last night was to use the PropVals method - but did not get all pieces to that puzzle. What are the necessary constants (besides FV_COLOR_SALMON) and how to assign the properties to the color? Would it be something like this?
var oProps = new PropVals() ;
var propVal = new PropVal() ;
propVal.propIdent.num = Constants.????;
propVal.propVal.valType = Constants.FT_Integer;
propVal.propVal.ival = Constants.FV_COLOR_SALMON;
oProps.push(propVal);oColor = oColor.SetProps(oProps);
It was to late in the day for these experiments...
And the method you present is much more transparent to me. So my final codeis this:
#target framemaker
OK = DefineCharFmt ("0-A", oDoc, 0, true); // just AsIs
$.writeln (OK);
OK = DefineCharFmt ("0-B", oDoc, 1, false); // AsIs + superscript
$.writeln (OK);
OK = DefineCharFmt ("0-C", oDoc, 2, true); // AsIs + colour Salmon
$.writeln (OK);function DefineCharFmt (sName, oDoc, iType, bModifyable) {
// In sName: name of character format to be checked
// oDoc: current document
// iType: Type of character format property to set
// 0 all set to AsIs
// 1 superscript
// 2 predefined colour Salmon
// bModifyable: see msg
// Out false, if char format is not defined (even after user prompt)
// Reference Rick Quatro at https://forums.adobe.com/thread/2240616
var msg, charFmt = 0, oColor = new Object (Color);msg = "Character format '" + sName + "' does not exist in catalogue\nShall it be created?";
if (bModifyable) {
msg = msg + "\n\nYou may modify the character format later to your desire, e.g. other colour";
} else {
msg = msg + "\n\nDo not modify the character format later!";
switch (iType) {
case 0:
break;
case 1:
charFmt.Position = Constants.FV_POS_SUPER; // FV_POS_NORM, FV_POS_SUB
break;
case 2:
break;
default:
alert ("DefineCharFmt:\nPgm error: case " + iType + " not defined.", "DefineCharFmt", true);
return false;
return true;
} else {
return false; // No character format defined
return true;
