This was available in 2015.3 from the Print commands Print...->Printer...->change Layout to Fiery Features but no longer appears in InDesign 2017. Without this I cannot access the sophisticated feature set available in the Fiery hardware attached to our Canon IRC 5255 MFD. Has anybody else experienced this and do you have a solution? Note that I have tried restarting the computer and reinstalling printer drivers...
Mac OS X 10.11.6
Your Fiery software probably needs a update which may not be ready for CC 2017. (This is a completely new version which has a new SDK for developers.)
Revert to CC 2015.
I'm solely do not recommend to print directly from InDesign to any professional printer.
Use PDF that you can do from InDesign.
I've found that print problems from ID usually are the fault of the print driver. I drive my large format Epson with a 3rd party RIP (similar to the Fiery) and don't have any problems printing directly from ID.
Is InDesign finding the PPD for the RIP—you should see it under printer in the Print dialog? See this thread PPDs Missing after 2017 Indesign Install -- A Prepress MUST
Are you able to access the Fiery Features page when printing from other applications? As I understand it, once you've clicked Printer from ID's Print dialogue, you've effectively left ID, and it's the OS X printer driver that reads the printer features from the PPD.
I'm using ID 2017 under Sierra with a Fiery IC-308 here, and the Fiery Features are there.
