I have a mail merge of about 135 people. The data is in Excel which I have turned into a comma separated file (CSV). I then loaded this file as the source and went through the basic settings. But when I tell it to merge it creates one merge per page instead of loading multiple records (in this case 25 records) on one page. The only thing I have changed is the update to inDesign and I have been doing it the same way for over 6 years.
I have attached some images that show my inDesign version and the settings I am using. I hope you can help me cause this is due in less than 24 hours.
Kim Huff
Hi Kim,
Can you share a sample CSV file so that we can test it at our end as I tried to reproduce the same and it works fine here. Also share your workflow.
Om
Hello Om,
I have emailed these files to the email address you gave me. I hope you can figure it out cause I have less than 12 hours to deliver and I still need to print!
Sorry to bother you on Thanksgiving, but WOW I am glad you are available.
Happy Turkey Day to all those at Adobe... you all ROCK!!
Om,
Just thought I'd let you know that one of the other Adobe specialist heloped me fix the issue. I guess the file itself was corrupt some how. but it all worked and I was able to get everything printed.
Kim
Hi Kim,
Thanks for the confirmation.
Om
