How to apply fillColor tint?
Nov 24, 2016 Nov 24, 2016
Hello – my script reads a CSV file (which holds path names and corresponding tint values) and tries to apply a tint to each named path. All paths have previously been filled with 100% of a Spot color.
The script (below) builds on something that Muppet Mark generously supplied for someone else's question a while back. It works fine if I change the opacity of the objects, but not if I change the tints. Can anyone please show what I'm doing wrong?
Many thanks.
#target Illustrator
applydatafile();
function applydatafile() {
          if ( app.documents.length == 0 ) { return; }
          var doc, csvFile, i, fileArray;
          csvFile = File.openDialog("Choose the CSV file");
          if ( !csvFile.exists ) { return; }
          fileArray = readInCSV( csvFile );
          doc = app.activeDocument;
          // For each line of the data file...
          for ( i = 0; i < fileArray.length; i++ ) {
          // ...get the named path [0] and give it property value [1]
          // this works: doc.pathItems.getByName( fileArray[0] ).opacity = fileArray[1];
          // but the following line has no effect:
          doc.pathItems.getByName( fileArray[0] ).fillColor.tint = fileArray[1];
function readInCSV( fileObj ) {
          var fileArray, thisLine, csvArray;
          fileArray =[];
          fileObj.open( 'r' );
          while( !fileObj.eof ) {
                    thisLine = fileObj.readln();
                    csvArray = thisLine.split( ',' );
                    fileArray.push( csvArray );
          fileObj.close();
          return fileArray;
CSV file contents:
one,35
two,55
three,75
four,95
Message was edited by: David Entwistle to aid clarity.
Scripting
706
Community Expert , Nov 24, 2016 Nov 24, 2016
Hi David_Entwistle
how about this?
applydatafile();
    var doc, csvFile, i, fileArray, pI;
        pI = doc.pathItems.getByName( fileArray[0] );
        if (pI.fillColor.tint == 100) { /
Adobe
Hi David_Entwistle
how about this?
applydatafile();
        if (pI.fillColor.tint == 100) { // change only if tint value == 100
        pI.fillColor.tint = pI.fillColor.tint *(fileArray[1]/100);
          fileArray =[];
                    $.writeln (fileArray);
          fileObj.close();
          return fileArray;
Have fun
Thank you! That does the trick, and very neatly.
(I had to add some semi-colons after the closing braces, lines 15–17, but not sure if that's something to do with my set-up.)
Very grateful for your coding and your time – thank you again.
