Can someone assist me in finding templates? Do you have to purchase all of them or are there free ones?
Nov 25, 2016 Nov 25, 2016
Looking to create a front/back cover of a book in a 6x9 format size. I have the template of how it should be, but it's a locked version, thanks.
770
You've posted in the non-technical forum Lounge.
Based on your question, can we assume you're looking to create a Book Layout with InDesign? See link below for details.
http://www.diybookformats.com/indesigntemplates/
If not  InDesign, which Adobe software product?
Nancy
Nancy O'Shea— Product User, Community Expert & Moderator
Alt-Web Design & Publishing ~ Web : Print : Graphics : Media
I am hoping to create just the cover, front and back to upload into CreateSpace, part of Amazon. The book was formatted in InDesign, but the gal I'm assisting wants the cover as a different document.
Thanks for your reply Nancy. I am assisting a friend who has already formatted her book using InDesign, but the software she is using to publish her book (Amazon CreateSpace) says to use a different file for the cover (front/back). So, I'm trying to find a template specifically for a 6x9 front and back cover that will include the bleed/trim/barcode, etc
I am an Amazon author, and I send my book covers as simple JPG files... create in any program you want, and export as JPG
Really? Do you use CreateSource? I am only familiar with Word. Does that work?
You don't need bleed for an eBook and it's not customary to have a back cover, though you can of course.
The normal workflow is to create an ePub 3 in InDesign, validate it and then  convert that file to the mobi format.
It's going to be in print format.
What is an ePub 3?
This is the spec for ePub 3 (for those following this!), but as you're producing a printed book, it won't concern you: EPUB 3.0 | International Digital Publishing Forum
Thanks Derek, much appreciated for the feedback.
Yes Nancy thanks so much. One question, still learning here, is there a video that shows it on a pc instead of mac?
Is the cover for a mobi file?
I am unsure what MOBI is?
Guru ,
Are you talking for printing? This is a good simple tutorial: http://indesignsecrets.com/indesign-secrets-video-laying-book-cover.php
The size of your document for the cover will be 12inches wide plus spine width plus 1/8 each side for bleed x 9 inches plus 1/8 bleed top and bottom. The spine width will depend on the number of pages of the content and the substance of the stock.
Normally you would supply the printer with a PDF using the InDesign presets selecting PDF/X-4 (unless your printer had supplied a spec),
The paperback is going to be a 6x9 size.
As I understand from CreateSpace, the following is needed
Bleed (0.125") + Back cover trim size (9) + spine width (90 pages x 0.002252 = 0.20268) + front cover trim size (9) + Bleed (0.125") = 18.45268.
Now, I've gotten this much from CreateSpace, but was looking for a template to fill in the info. The only one I found online is a pdf and I can't make changes to it.
In InDesign you create a new document with Print as the intent. The size of the  will be 12" (plus spine width) x 9 inches. To this you add bleed to all edges 1/8 (.125").
What does this figure in your post mean: 18.45268?
Why do you need a template, add guides for the spine and create your design in the space.
By the way, I assume your book is portrait (not landscape).
Mentor ,
Hi
This seem a paperback in landscape orientation.
You won't find a perfect template since "spines (width)" can vary all the time (for number of pages). For the horizontal width of the document, use the printer number and add guides for the spine.
Pierre
Nov 26, 2016 Nov 26, 2016
It's locked that you can't open it? It's locked that you can't save it? It's locked that you can't work on it?
InDesign does not lock files. If it is locked at the operating system level, you can do a Save As. If the layers are locked, you can unlock them. If the items have dotted lines, they are on the master pages.
If what you have is really a template, then the extension is .indt and when you open it, it is untitled. What is the extension?
