I'm hoping someone may be able to resolve an issue in the develop module which, as far as I know, presented itself out of the blue.
The problem is this :
When selecting an adjustment tool, such as spot removal, graduated filter etc and then applying its effect onto an image the image is automatically moved from its current location in the photo queue to the beginning. This is very annoying as it affects the workflow. Lightroom was not doing this initially and I am unaware why it has changed behaviour. I am not aware of any settings I have changed to cause this issue.
I would appreciate any advice . Thanks
Windows PC
I7 6700k
32GB Ram
500GB SSD
Change the sort order to by capture time
Use the menu command View->Sort
That did it - thanks a lot.
As above but you have to be in the Library module to change that setting. No such command in the Develop module.
It is now, more than likely, set to Edit Time. Which would put newly edited images at the front of the list.
Much appreciated - I'll make a note of that so I don't forget.
