Hello everyone:
i draw an off-road vehicle and hills with separete illustrator file and it's take much time to animate vehicle's x-y positions and rotation.
You know AE's path animations feature but i want to animate vehicle along to hills path.can AE read illustrator's path?
Copy the path in Illustrator. Select a layer in AE. Choose the pen tool and click anywhere and paste, press Alt/Option + m to set a mask keyframe, copy, select any position property and set a keyframe by pressing Alt/Optio + p, then paste.
Your Illustrator path turned into a mask path then into a position path. AE Basic skills everyone should have.
you probably mean you want to use the path as position keyframes. you can do that:
copy the path property and paste on to position. to make the rotation orient along path use the orient along path feature: layer->transform->auto orient
No i know how i use path as position keyframes and along path feature for rotation.i am just asking how can i use adobe illustrator path in After effects?
actually: Your Illustrator path turned into a mask path then into a position path.
I always create a position path first to make sure it's in the right place.
you can, but it's unnecessary for the technical procedure that's what I'm saying.
copying illustrator paths (or Ps paths) is very simple: copy (Ctrl+C) the path from illustrator, paste (Ctrl+V) in Ae. if you want to paste it on position you can do it without creating a mask first. more information here: https://helpx.adobe.com/after-effects/using/creating-shapes-masks.html#copy_a_path_from_illustrator_...
