Locked
Error when uploading my site to Business Catalyst (Failed to update CRC's)
Participant ,
Nov 26, 2016 Nov 26, 2016
Hello, I am working on a website with Muse and I am trying to upload it to Business Catalyst. I did upload it before and the first time was successful, however, I deleted the site from the BC, and I tried to upload it again. Now it gives me this error message and Muse quits right after I close the message. I have no idea how to fix this issue. Can anyone help me with this please! Thank you!
562
Participant , Nov 26, 2016 Nov 26, 2016
I tried deleting each page and uploaded to BC to see which page was causing the problem. And I found out it was the contact page. And then I found out it was the font I was using that was causing the problem. I was using Century Gothic, which is a system font. I changed it to a font in Type Kit, and it solved the problem. If the system fonts cause the problem, I wonder why they are there to choose... System fonts also cause problem when trying to use in-browser editing. I took long time to figur
how did you do that? if you used the manager then try uploading as a new site name... that should get around the blockage
Participant ,
Thanks for your replay. I just tried uploading as a new site name but it gave me the same error... I deleted it from the Site Manager on BC. I also noticed this when I was trying to upload it to BC.
Ahisa71 wrote:
Thanks for your replay. I just tried uploading as a new site name but it gave me the same error... I deleted it from the Site Manager on BC. .
the name for the old site is now in limbo and the dns entry will need to be fixed before you can use that name again... takes up to a week.
the other site was fully published? ... the text font points to the old site but thats easy to fix once you get a new site up
steps for making a new site name for the old .muse file*
  • set the publish option to Adobe BC
  • press publish and select the options arrow
  • change the name box to the "new site" option
  • select a data center that allows your users to get fast rendors and type a new name... can't be the old one!
  • after this new site is published you can set type options, in browser editing and a new dns name etc... launch the site fully for these options
* a .muse file made on a different computer will need to be unblocked before use with windows 8.1 or 10
Participant ,
Hello again,
No, I changed the name and tried uploading it as a new site, but it still gives me the same error and the Muse quits, so I cannot really do anything...
Dec 05, 2016 Dec 05, 2016
No it didn't help because I don't use Business Catalyst. I upload through FTP and it crashes my program. I have clients who will be really upset if they don't see changes soon.
Participant ,
I created this thread for uploading error with Business Catalyst, so I recommend you create a new thread for your issue. Hope you'll find a solution soon!
Participant ,
I tried deleting each page and uploaded to BC to see which page was causing the problem. And I found out it was the contact page. And then I found out it was the font I was using that was causing the problem. I was using Century Gothic, which is a system font. I changed it to a font in Type Kit, and it solved the problem. If the system fonts cause the problem, I wonder why they are there to choose... System fonts also cause problem when trying to use in-browser editing. I took long time to figure out that one, too. Don't use System Fonts, people! But thank you for your help!!!
I've just removed the original site from BC and gone through the steps Ahisa71 posted and it still doesn't work, now my client has no site.
Participant ,
I started using Muse only recently but it seems it's not stable sometimes. Some actions which used to work don't always work. So, some problems might just be due to luck..... The Century Gothic font I mentioned had been working with no problem for about a month, and then suddenly started causing problems. Sorry but I don't know how to solve your problem...
