I am using Cold fusion 9 and have to do an oauth2 call. I have never used cfc files - but there is example code using cfc's so I'm giving it a try (and failing) - but I don't know whether I'm failing with cfc or failing with the call.
My application.cfc and oauth2.cfc are in the same folder...
My application.cfc file is:
component {
this.name = "myApplication";
this.applicationTimeout = CreateTimeSpan(10, 0, 0, 0); //10 days
this.datasource = "xxxxx";
Request.dbusername = "xxxxx";
Request.dbpassword = "xxxxx";
request.dsn2='xxxxxx';
Request.key="xxxxxx";
request.key4="xxxxxx";
request.key8="xxxxxxxxx";
request.dsn = 'x';
this.sessionManagement = true;
this.sessionTimeout = CreateTimeSpan(0, 0, 30, 0); //30 minutes
this.customTagPaths = [ expandPath('/myAppCustomTags') ];
this.mappings = {
"/foo" = expandPath('/com/myCompany/foo')
// see also: http://help.adobe.com/en_US/ColdFusion/10.0/CFMLRef/WSc3ff6d0ea77859461172e0811cbec22c24-750b.html
// see also: http://help.adobe.com/en_US/ColdFusion/10.0/Developing/WSED380324-6CBE-47cb-9E5E-26B66ACA9E81.html
function onApplicationStart() {
return true;
function onSessionStart() {}
// the target page is passed in for reference,
// but you are not required to include it
function onRequestStart( string targetPage ) {}
function onRequest( string targetPage ) {
include arguments.targetPage;
function onRequestEnd() {}
function onSessionEnd( struct SessionScope, struct ApplicationScope ) {}
function onApplicationEnd( struct ApplicationScope ) {}
function onError( any Exception, string EventName ) {}
My oauth2.cfc file is:
component accessors="true"
property name="client_id";
property name="client_secret";
property name="authEndpoint";
property name="accessTokenEndpoint";
property name="redirect_uri";
public oauth2 function init(
required string client_id,
required string client_secret,
required string authEndpoint,
required string accessTokenEndpoint,
required string redirect_uri
setClient_id(arguments.client_id);
setClient_secret(arguments.client_secret);
setAuthEndpoint(arguments.authEndpoint);
setAccessTokenEndpoint(arguments.accessTokenEndpoint);
setRedirect_uri(arguments.redirect_uri);
return this;
public string function buildRedirectToAuthURL( struct parameters={} ) {
return getAuthEndpoint() & '?client_id=' & getClient_id() & '&redirect_uri=' & getRedirect_uri() & buildParamString(argScope = arguments.parameters);
public struct function makeAccessTokenRequest( required string code ) {
var stuResponse = {};
httpService = new http();
httpService.setMethod("post");
httpService.setCharset("utf-8");
httpService.setUrl(getAccessTokenEndpoint());
httpService.addParam(type="formfield", name="client_id", value="#getClient_id()#");
httpService.addParam(type="formfield", name="client_secret", value="#getClient_secret()#");
httpService.addParam(type="formfield", name="code", value="#arguments.code#");
httpService.addParam(type="formfield", name="redirect_uri", value="#getRedirect_uri()#");
result = httpService.send().getPrefix();
if('200' == result.ResponseHeader['Status_Code']) {
stuResponse.success = true;
stuResponse.content = result.FileContent;
} else {
stuResponse.success = false;
stuResponse.content = result.Statuscode;
return stuResponse;
public string function buildParamString( struct argScope={} ) {
var strURLParam = '';
if(structCount(arguments.argScope)) {
for (key in arguments.argScope) {
if(listLen(strURLParam)) {
strURLParam = strURLParam & '&';
strURLParam = strURLParam & lcase(key) & '=' & trim(arguments.argScope[key]);
strURLParam = '&' & strURLParam;
return strURLParam;
and my test16.cfm file is:
start
<cfset Greeting = CreateObject("Component", "xxxxx/components/oauth2.cfc") />
<cfset myGreeting = Greeting.getGreeting(client_secret="xxxsecretxx", authEndpoint="xxxxwhere itgoes tobeauthenticated",client_ID="xxxclient_IDXXX",accessTokenEndpoint="xxxwhereitgoesafter",redirecturi="xxxxwhereitisredirectedxxx") />
<cfoutput>
#myGreeting#
</cfoutput>
end
It goes to start...never gets to end
the debug message:
16 ms | 16 ms | 1 | D:\Websites\ToolsForBusiness\disaster1\components\test16.cfm |
0 ms | 0 ms | 1 | CFC[ D:\Websites\ToolsForBusiness\disaster1\components\application.cfc | onError([complex value], onRequest) ] from D:\Websites\xxxxx\components\application.cfc |
0 ms | 0 ms | 1 | CFC[ D:\Websites\ToolsForBusiness\disaster1\components\application.cfc | onRequestStart(/components/test16.cfm) ] from D:\Websites\xxxxx\components\application.cfc |
16 ms | STARTUP, PARSING, COMPILING, LOADING, & SHUTDOWN | ||
16 ms | TOTAL EXECUTION TIME |
Have something to add?
