I have a shapelayer line and I will animate that path.
I have an object that would be stuck on one of the edges in that path.
Its a lamp and the bulb with be at the top pf the line.
Could you synk that point in the shapelayer with the object of the bulb?
/ Matitas
1. unfortunately Ae does not natively support this type of operation because a user can't access the path vertices coordinates that easily. you can do this with this script BAO Mask Avenger 2 - aescripts + aeplugins - aescripts.com which I have used myself and is very handy. through the script you can create live nulls that are attached to a path vertices (masks or shapes) and once you have that, you can do many things and attaching an object is one of them. it's cyber monday 25% off today BTW.
2
...Copy link to clipboard
2. if your path has only two points, you can use the beam effect that comes with two position cross-hairs on each edge.
3. you could do this manually if it's not to complicated and adjust the keyframes by eye
Thanks! for good answer.
Yes a 2 point shape is not so difficutl to do manually. I was think if you made more complicated things::
/ Mattisa
