Got a strange error after the last update of After Effects 14.0.1.5.
I Cant import image sequenses in the right frame rate. I have the Import preferences set to 25fps as I Always have, but when then import a .jpg sequense rendered out from 3ds max or premiere and add it to the timeline I get this " Error zero dominator in ratio muliply"
If I change the preferences to 30fps and import and then interprete the file to 25fps it works until I save the file then all imported clips gp back to 30fps and I need to interpete them again.
What has happen is there a bug or something I missed in the uppgrade, I have tried to uninstall and install again but the error is still there.
Andreas
there is a bug with jpg sequences in CC2017. see it here: Known issues in After Effects CC 2017 . more workarounds here: Re: AE CC 2017 - BIG Bug interpreting the FPS of the sequence of images
All old Project get the same message!!!
I installed version 2015.3 and it works fine, something strange must have happen in version 2017
I got the instructions to use AE 2015 but I can render as .png from 3dsMax and everything works Ok. But the next update this maybe is fixed.
