Hello everyone, i have acrobat 9 standard and i cant scroll down to see all pages in the pages table.
Like on a combine pdf of 227 pages i only see at 225.
If i enlarge the view of the thumbnails i see it every page but for editing its very annoying. (to drag pages)
Someone have a idea what to do?
Thanks you very much.
Make sure you update to the latest version that you can, via the Help menu.
Hi, thanks but there is no update or check for updates button on the acrobat (help button)
What version do you currently have? Check under Help - About Adobe Acrobat...
hi, 9.3.0
The latest version available is 9.5.5. You can get the updates from here:
ftp://ftp.adobe.com/pub/adobe/acrobat/win/9.x/
Note that you need to install them in ascending order, one by one.
On Mon, Nov 28, 2016 at 12:38 PM, meitarm17942032 <forums_noreply@adobe.com>
Hi again, thanks.
I cant install the v 9.5.5 on 9.3.0??
No, you need to follow the correct order of updates. See the comments to this blog post about how to modify the system time to potentially force an automatic update: Where are my Adobe Acrobat 9 Updates??? - KHKonsulting LLC
No, they are cumulative updates.
Im going to try, let you know...
Thanks you
Hi, i make the update at the v.9.4.6.
There isn't the 9.4.7 or 9.5.0 for the update to me. Is for normal acrobat but i have the me. And for the 9.5.1me give to me a error because there isnt the 9.5.0.
The problem it isn't solved yet...
What can do for the updates or something else for correct the problem??
What's your OS? Acrobat 9 is quite old and not compatible with the current systems.
For 9.4.7 and 9.5.0 there are no separate versions for ME.
Hi, the os its windows 10 pro
And bernd, i downloaded the 9.5.1 and give to me an error that i need the version before 9.5.1
Acrobat 9 is not compatible with Windows 10.
On Tue, Nov 29, 2016 at 2:20 PM, meitarm17942032 <forums_noreply@adobe.com>
and if i install acrobat with compatibility mode (win 7)??
It's better, but it won't change the fact that the two are not officially compatible.
im going to try, tell you later..
thanks
I, it dont solved the problem to run the acrobat on compatibility mode with win 7..
another option please?
Yes, install the updates 9.4.7 and 9.5.0.
Yes, i wanted too, but in the ftp there is no update for 9.4.7 and 9.5.0 for version of adobe 9 standard me
There are no separate versions for ME. Use the versions in the ftp site.
Hi bernd, i updated to the v. 9.4.6, and i cant update to the v.9.5.5 because the 9.4.7 and 9.5.0 doesn't have the STANDARD ME update on the ftp. what to do??
Use the versions 9.4.7 and 9.5.0 in the ftp site.
but there isnt those updates in the ftp site for ME version.
and the v9.5.1 cant install without those updates...
