Since updating to InDesign CC 2017 I have noticed that formatting text, moving text, basically anything having to do with text boxes is extremely laggy. If i move a text box across the screen, the text goes invisible within the text frame and does not reappear for several seconds or until I double click within the text box. Very annoying. Is anyone else having this issue/does anyone know how to fix this?
Have you tried to delete the preferences and the cache of InDesign? I so this behaviour could be a third party InDesign plugin which isn't yet compatible with CC 2017.
Try disabling the Type Contextual Controls, and let us know if that makes a difference.
I have the same problem. When selecting text inside a text box, the spinning beachball appears and only after about 5-6 seconds, the text appears selected as it should.
Deselecting the "Show Adornment..." option did not change the situation.
Steven
Did you turn both checkboxes inside the orange rectangle off?
No, I did leave the upper option selected. I will further test, with both options deselected.
Hi!
Unchecking both checkboxes fixed it for me.
best,
Ilya
Excellent!
Seems to work for me too. Although at a loss of some interesting functionality, at least work just flows again.
Steven
Adobe has indicated they are working on resolving this issue, so hopefully, the loss of functionality is just short term.
An no third party Plugin installed?
Best regards
Haeme
And yes, I do have Suitcase Fusion 18.2.0.1164 (plug-in version) installed and running.
Best regards,
Steven
