After Effects CC (November 2017) Bug-Fix Update Is Now Available | Creative Cloud blog by Adobe
The 14.0.1 bug-fix update for Adobe After Effects CC (November 2016) is now available. This update fixes multiple bugs, including fixes for After Effects hanging or crashing during previews.
You can install the update through the Creative Cloud desktop application, or you can check for new updates from within any Creative Cloud application by choosing Help > Updates. Please note that it can take 24 hours or more for all of our global data centers to receive the update. If the update isn’t available for you right now, please check back later.
For details of what was added, changed, and fixed in the 2017 release (version 14.0) of After Effects CC, see this page. For details of all of the other updates for Creative Cloud professional video and audio applications, see this page.
The 14.0.1 bug-fix update for After Effects addresses these bugs:
I installed bug fix yesterday and thought "Finally, it's good now". Working now, same problem, no realtime playback (old issue on CC 2015 and CC 2017)
Mac OS Sierra, Mac Pro, 2 x 2.4 GHz 6-Core Intel Xeon, 64 GB Ram
It's becaming really frustrating, we're trying to do some work here and all we want is stable and realtimeplayback working piece of software, are we asking too much?
I'm sorry to hear that you're still having problems. A significant bug with real-time playback was fixed in the 14.0.1 update, so it's probable that you are encountering other problems.
Is color management enabled in your project? If so, please provide details.
Is Mercury Transmit enabled in Preferences > Video Preview? If so, please provide details.
Is Hardware Accelerate Composition, Layer, and Footage Panels enabled in Preferences > Display?
What is the resolution of your monitor? Is it an Apple Retina display?
HELLO , I have problem with not RealTime (FPS) How fix this ? Thank You !
My PC Specs :
CPU : Intel Core i7 5820K
GPU : MSI Nvidia GeForce GTX 980 Ti
RAM : Corsair Vengeance LED 3000 MHZ 32GB DDR4
Motherboard : MSI X99A Gaming 9 ACK
SSD : Corsair 480G LE
Thank You !
Sorry I don't want to highjack this thread but because I have a very similar playback stutter issue in AE CC21017 v.14.0.1.5 I would like to provide some maybe useful Information. And because of your questions to an other user I was able to track down my issue.
With the following settings from below Ram Preview Playback is ok, in realtime and in sync with the frame rate settings for playback.
Project Settings Color Depth 8bpc or 32bpc
color management = Off
Mercury Transmit enabled in Preferences = Off
Hardware Acceleration Composition,Layer, and Footage Panels = On
But when working in 16bpc Color Depth with the same Settings from above Ram Preview Playback is stuttering like hell although After Effects says Realtime Playback is 25fps I only get a maximum playback rate of 2-5 fps. Sometime it doesn't play at all! Also the composition viewport is very slow and is lagging. It's not workable at all.
But when "Hardware Acceleration Composition,Layer, and Footage Panels" is turned OFF all seems to work fine in 16bpc Project Color Depth and Ram Playback is in realtime!
Why is it working in 8bpc and 32bpc but not in 16bpc when "Hardware Acceleration Composition,Layer, and Footage Panels" = ON? wierd!
I don't know but could this be a bug?
Best Felix
Felix, those are some very interesting results. Very possibly a bug.
Can you do me a favor and file a bug report for this, at the address below? I'll take that and follow up with our developers. Thanks.
Hey Tim,
Bug report is filed
Thanks for taking care of it
Felix
Hi Tim,
How can I install that bug-fix ? I don't know why but it isn't available form me ? In CC app I have info that all my apps are updated ?
But my After Effect still have a problem when I try to go preference >>> Audio Hardware ...
check your version. is it 14.0.1? if it's not you should try to update and read these instructions and see if that helps:
Available updates not listed for Adobe Creative Cloud applications
Roei it was helpful, thanks !
I choose a 5th solution - unistalled after effect but before I did this I checked my version and it was 14.0.1.5
Hi All,
that bug came back ... Now I have AE 14.0.1.5 and few days ago uninstalled and install AE again to repair that stuff.
Audio Hardware >>>
When it will be fixed ?
Piotr1986,
There is a known bug in After Effects CC 2017 where, if you unplug or change the audio device that After Effects was using, After Effects will crash the next time you try to open the preferences. What's happening is that it is trying to initialize that device but can't. The workaround is to reset the preferences, or at least trash the Adobe After Effects 14.0 Prefs-indep-general.txt file, which stores the audio device references. The problem will recur if you choose the same audio device again.
We intend to fix this in the next update to After Effects. Sorry, but I can't give you a date for that right now. Our apologies for the disruption from the bug.
What audio device, specifically, are you using with your computer? Manufacturer and model number, please. How does it connect to your computer? What driver version? What version of Windows are you using?
Hi Tim,
Thank you for explanation so I need to wait until the fix update will be ready....
And it's true the AF crashes when I try to change my audio devices. I'm working on mobile work station HP Z book G17 (i7-6700HQ, AMD FirePro W6150M, 16GB 2133 DDR4 ram, 1,5 T SSD, win 7 enterprise 64-bit 6.1, built 7601, sp1) so when I'm in the office I have connected Bluetooth Samsung headsets (HS6000) -windows drivers, but lats weekend I work form home and I connected just normal apple earphone.
I hope it will be helpful for you and If you have any questions, do not hesitate to contact me
Hello,
just to say the same occure here.
By updating cg card, the audio hardware mapping changed.
So ae start by put an error
i closed the audio panel and resolve this message in the first way.
next i wanted to changed prefs, but ae crash.
then i reset my prefs (so i lost my workspace) then it worked (but some prefs has been deletd like "missing footage" defaut choice in search panels (i had to restore it in prefs file).
then today, my audio card unplugged then pugged again (it happen sometimes as my sound is played on my screen speakers, as i listen to the sound with headphones, when it goes to screensaver). So i have to redo the same again.
hope you will fix this issue soon.
thanks
Anticipating this update.
I occasionally bring my USB gaming headset to my office from home when working on audio. When finished, I closed AE and took my headset home. Now that it isn't plugged into this computer audio doesn't work in AE and I cannot change the setting.
I LIKE having the ability to choose my audio output inside the program. But with the Win 10 Anniv. update changing audio outputs is easy a pie. Perhaps while the devs are fixing this bug, they can also add this feature:
Enumerate the audio hardware (as AE currently does) and let us choose from the list, but include the generic Windows Sound Mapper (which AE currently does not do). An example of this in practice is Audacity.
Thanks for listening (reading).
I'm still getting the audio playback error where the audio doesn't play until about 1 second into the preview.
It's very annoying as I have to disable the 'Mute Audio When Preview Is Not Real-time' which means I have to listen to the audio in slow motion every time I cache the timeline.
Is there a way around this issue anyone knows of?
You can also work around this problem by disabling the Hardware Accelerate Composition, Layer, and Footage Panels option in Preferences > Display, or by disabling the Cache Before Playback option in the Preview panel.
If you are using color management in After Effects, disabling the Hardware Accelerate option may have a negative impact on playback performance, so I recommend trying the other possible workarounds first.
More detail about this bug, from this page:
Hello Tim Kurkoski​
when will we expect for an update for this bug ?
i can't wait anymore to listen the sound in after effects or i have to reset very often ma prefs, as soon as my prefs crashes after....
very very unconvienient
We intend to fix this bug in the next update for After Effects, which we are planning for early next year. (Sorry, I can't be more specific about the release date.)
ok thanks
Hello,
any news ?
can't wait for this bug fix, a real waste of time...
The bug where After Effects crashes when opening the preferences after an audio device has changed will be fixed in the next update for After Effects.
I can't share the release date of the update yet. "Soon" is the best I can offer.
Soon is better than nothing, hope not soon too late !!
Hey any update on this bug, i didn't have this bug till yesterday, making it really hard to work. please fix.
