Locked
Ressources over sampled
Contributor ,
Nov 16, 2016 Nov 16, 2016
Starting Muse project I have a message for several ressources over sampled. In my ressource panel there is NO ressource with this message !!!!
How can I find my over sampled ressources ?
Thanks for the help
Jean
599
Hello,
Please check this video for more info in resampling in Muse - Understanding the size and resolution of your graphics
This forum link might also help you - Placed FW asset into Muse. Original Size = 908w x 2323h. Muse auto resampled to 800w x 2048h. I need... ​
Ankush
Contributor ,
Nov 17, 2016 Nov 17, 2016
Hello
Thanks for your answer, but my problem is when my muse project is loading I got a message :
"The document has 9 links to OVER SAMPLED ressources, please....."
ANd when I check the ressource status in ressource panel, all ressources are OK,
There is not one ressource with "over sampled" status, So how can I find these 9 ressources ?
Thanks for your help
Regards
Jean
Check this thread - document contains 2 links to assets being upsampled, it's exactly the same issue you are facing.
Contributor ,
Nov 18, 2016 Nov 18, 2016
Hello
Thanks, I tried to relink all resources but it does not solve all problems. (I came from 9 problems to 3 and then back to 7 without any reason or message !!!)
The proposed solution is " it VERY common to get false ones after letting muse auto update the .muse file but you can relink the photo (other images) and that should make it go away"
What means really  "other images" ?
Should I relink all images to some others and than came back to the correct one ?
Is there no solution to know where the problems are ?
Why are they not displayed in Resource panel ?
I have over 100 links !!!!
Best regards
Jean Kubler
Contributor ,
Nov 20, 2016 Nov 20, 2016
Hello,
By trying and relinking one by one all ressources without any success. I found a very strange situation. My main page has a back ground image.
Original size : 5000x3310
resampled size : 5000x3310
Max used size : 3539x2343
Status : HiDPI x2
The size of this image is linked to the number of  errors !!!!
With this size I have one link on error, if I reduce the size I get 6 or 7 links on errors !!!!!
Please help
What is the relation ?
If I resize the back ground image more to the used size I have 7 errors !!!
Is there i way to get a correct size for the back ground
Many thanks for your help
Best regards
Nov 21, 2016 Nov 21, 2016
Could you please attach a screenshot of the link errors which you are getting?
Contributor ,
Hello,
Here is the message I get, the number of over sampled resources is currently one, but just by re linking the main page back ground image it became 7 !!!!!
Best Regards
Contributor ,
Nov 26, 2016 Nov 26, 2016
Hi, Is there a way to find the over sampled images NOT MARKED AS in resource window ?
Nov 28, 2016 Nov 28, 2016
Although you are getting that warning, however, does it crash your Muse or corrupts the file?
Or your file looks good after uploading?
Contributor ,
Nov 30, 2016 Nov 30, 2016
Every thing seems OK, I have no idea of the source of that warning message.
The thing is, just by modifying a page the number of warnings is going up or down without any reason. And I am unable to see if there are "real" problems or not. If a warning is detected at load, it should be displayed in the resources panel.
Contributor ,
Dec 15, 2016 Dec 15, 2016
I got the last update of Muse
Still the same problem
Over sampled ressources are not marked in ressource panel
Please help
