I have Several Different cases where i'll need this. but hte on i just came across is ADVERTENCIA ¡ATENCIÓN!. How can i Bold the ADVERTENCIA and not the ¡ATENCIÓN! The below Picture SHows how i have it. As shown below Both words are bolded. I do not want ATENCION bolded in this case. Any time it has ¡ ! in it i want it to not bold. IF it just shows as ATENCIÓN (Without ¡ ! ) i want it bolded
Simple ¡\u+! should work, if you look for any word in caps, surrounded by ¡ and !.
A bit wider version: ¡\u*?\l*?! (mix of upper and lower case letters is allowed)
Or use directly ¡ATENCIÓN! if this is the only word that should be affected.
THank you. very much this worked.
