I did some searching here in these forums, but I haven't found a solution from the answers in those cases.
When I hover my mouse pointer over a menu item, it activates the menu item next to what I'm hovering instead. For example, if I hover over "Edit," the active menu is "Layout" and so on down the menu interface line.
I have cleared the preferences/cache.
I am also using a touch-screen laptop with a separate monitor. The screen on the laptop is turned off, making the monitor the primary display.
Anybody have any other suggestions on what I can try to resolve the UI problem?
Thanks in advance.
First things first. After reading this you may decide to help other users to help you more efficiently
