I am trying to Erase Computer Authorization and it says "Unable to Erase Authorization. Please try after some time." It didn't work yesterday and it won't work today.
The reason that I am doing this is because when I try to download a book to study for an upcoming exam, it says "Error! Check Activation."
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
I have windows 10 and those instructions do not help me to deauthorize.
Are there other instructions I can follow?
The steps should work also. Which step do are not found under Windows 10?
There is no start/run in windows 10. How do I find that?
Press WINDOWS + R and enter under this regedit and press enter.
