I am producing printed documentation from RoboHTML. Most of
the style mapping works correctly, but one instance does not. I
have a style named NumberedList in my project. The style attributes
in the project have no numbering option selected on the Numbered
tab, but the Number positioned within paragraph check box is
checked. I also do not use the automatic numbering feature on the
RoboHelp toolbar. The number for each step is typed manually.
In Word, I have a Numbered List style, which is what I mapped
the RoboHTML style to. It has customized numbered list attributes
set within the style through the Number and Bullets dialog. When i
have this custom numbering turned on, RoboHelp will not use the
Word style. It uses Normal instead for numbered lists. If I set the
Word style to use No Numbering on the Number and Bullets dialog,
then RoboHelp uses the Numbered List style. the text has numbers,
and it seems to use the attributes that are applied to the numbers
in RoboHelp (bold). However, in print, I want no bold and periods
after the numbers.
Any ideas as to why this might not be working or how to make
the Word number style different from the RoboHelp style? I can give
more details if needed.
Kelly
