How do I check activation? By dumb luck, experimentation, deleting authorization, re-authorization, deleting downloaded Overdrive books, downloading them again, I got 4.5 to work. Still have no clue WHY I started receiving errors on 2.0 that drove me to download 4.5 & delete 2.0 and start messing around. Cussing didn't help but I felt better. ADE proves there is no "free lunch" or truly free ADE. Users must agree to periodic torture sessions on non-helpful help sites.
I havae this same question but my messing around has not solved the problem. Why make it so hard to verfy. while in process. I have verified with download the program.
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
thanks Nanaky: this deletes your computer authorization for ADE, re-authorize and ADE works.
I cannot find Windows. Went to setting but have administrator, systems etc. which do I chose????
Sent from my iPhone
WIndows is a operting system kind of Microsoft. What you are found not exactly?
