Replace With After Effects comp causing speed changes to the top layer?
Nov 30, 2016 Nov 30, 2016
I am having issues with Premiere Pro and Creating linked After Effects comps.
I am trying to motion track a plate shot into a shot with green screen and AE is not being nice. I was on chat support with Adobe in India and they are clueless! They dont even understand what it is I am trying to do.
In Premiere I have 2 layers. 1st layer has the scene with green that I want to track & comp a plate into. The first several comps I need to do have the plate playing at 25% speed Nested and looped. And then some of the others have the Plate layer at 1500% spedup, looped and nested. When I select the the Green Screen layer  and plate nest and select replace with after effects composition it speeds up the  1st layer.
Is there a workflow thing I am missing here? I prefer to edit the layer content in Premiere for timing then bring in the layers to AE. I suppose the problem lays in my nested speed changed plates.
I thought nesting would have worked but it didnt? Do i need to export the plate loops and reimport as new clips?
any help would be great!
334
Yes, exactly. Render them out if you really must. From an AE perspective your workflow doesn't make much sense. Why would you even degenerate quality already by applying some sort of timewarp when you intend to replace something? Other than providing a timing refeence, you wouldn't do that and work on the native clips with AE's own time warping tools.
Mylenium
Adobe Employee ,
Jan 26, 2017 Jan 26, 2017
Hi richardp,
Did you solve your issue? Did Mylenium's advice assist you?
Kevin
