How to design an icon?
Dec 01, 2016 Dec 01, 2016
Hi All, I have scanned a JPEG drawing (public domain) and want to turn it into an icon for my website. Can I use PS5?
415
Community Expert , Dec 01, 2016 Dec 01, 2016
ok.
  1. Double click the Background layer to convert it from a locked layer to a regular layer. It will be Layer0
  2. Activate the Magic wand tool. On the tool's option bar, set tolerance to 16, and untick "Contiguous"
  3. Left click on a white area, then hit delete on the keyboard
  4. Press CTRL+D to get rid of the marching ants.
  5. You should see the drawing surrounded by transparency.
  6. Go to Edit>save for web. In the dialog select PNG24 for the file type, check "Transparency" and check "Constrain Proportions". For hei
The short answer is "yes."
You will probably want to remove the background from the drawing, then go to File>Save for web. In that dialog be sure that "Transparency" and "Constrain Proportions" are ticked. I usually make the long side 800 px or so.
Tx, Hatstead. Mine is a thin-lined drawing (not unlike the Olympc rings) and I just need the lines, not the background. The magic selection brush ctrl-W is fooled by the lines. My plan is to isolate line from background (i.e. your approach) and then thicken and smooth these lines. Does this make sense? Rgds. Tim@Amsterdam
Yes, that's the goal.
Is the background a solid color or is it a complex background?
If you are so inclined, post the drawing so that we may offer more targeted guidance.
Black lines on a white background, Hatstead. It is the epitaph of Stevinus, a Flemish scholar (1548 – 1620). Tx, TimIMG selected.jpg
ok.
  6. Go to Edit>save for web. In the dialog select PNG24 for the file type, check "Transparency" and check "Constrain Proportions". For height type in 800 px, leave width field blank.
  7. Note: PNG supports transparency. If you save it as JPEG, you will have a white background again.
Great help! I did find that edit>save for web, but hidden as "export file>save for web (reference to it being outdated)". It did do the job. Using Photoshop 2015.5 and learned that it required updating too.
Good luck with your web site.
